AutoCAD 2010/2011/2012
New Member
mkirby1
Message 1 of 5 (2,138 Views)
Batch autocad conversion to earlier release
2138 Views, 4 Replies
01-19-2011 07:10 AM
Is there a way to batch convert acad files back to acad 2000 from acad 2011? If it cannot be done within the autodesk software can someone recommend a 3rd party program that I can download that is cheap or free. Thanks for the help.
Distinguished Mentor
michael.robertson
Message 2 of 5 (2,117 Views)
Re: Batch autocad conversion to earlier release
01-19-2011 08:18 AM in reply to: mkirby1
If you are on subscription there is a DWGConvert tool on the Subscription tab. The command is DWGCONVERT
There is built in setup for going back to 2000, 2004, & 2007 or you can build your own.
Mike Robertson
FL. Dept. of Transportation
CADD Applications Developer
Valued Mentor
TrevN
Message 3 of 5 (2,113 Views)
01-19-2011 08:47 AM in reply to: michael.robertson
Have a look at Batch Converter within AC, that should do the trick!
*Expert Elite*
Message 4 of 5 (2,090 Views)
01-19-2011 11:25 AM in reply to: mkirby1
Just use eTransmit and change the file version under options to whatever you want.
*Expert Elite*
dgorsman
Message 5 of 5 (2,084 Views)
01-19-2011 11:36 AM in reply to: mkirby1
Trueview: AutoDesk *and* free.  Not only down-converts but also includes clean/audit, removal of printer references, scrubbing of visual fidelity for annotative objects, and resetting annotation scales.  Send your client/recipient a link to the download page so they have it as well, just in case you miss a file or two.
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
