I had a .dwg file open in AutoCAD when I had to force the program to shut down from the Windows task manager. (It had been frozen for a long time.) I then double-clicked to open the folder where the .dwg should have been, and it was not there. Instead there was only a .bak, .dwl, and .dwl2 of the file. I understand that I can change the .bak extension to a .dwg extension to at least use the backup copy, but is there anything else I can do?
notes:
1. Strangely enough, the .bak I have for the file is at least two saves behind, it's not as recent as it's supposed to be.
2. Also, the drawing recovery manger opens when I open a new picture, but it shows the folder the lost file was in, and when I click the folder on the drawing recovery manager, there's no file inside.
3. I cannot attach a file, it contains confidential client information.
hi, go to options>change to "SV$" (file extension for temporary files)>go to files create folder in your c: drive (or any drive available). Any unexpected error/crash just go to folder you have created and rename the .bak or .SV$ to .dwg and you will retrieve the latest drawing. Hope it helps. thanks
Please find attached.
Was there a .TMP file (around the same date/time)?
When AutoCAD saves a drawing, it
* writes the contents of the editor to a .TMP file.
* renames the DWG to BAK (deleting the previous BAK in the process)
* renames the TMP to DWG
So if something happens between step 1 and the completion of step 3, the DWG file may be missing but the TMP might still be OK.
