AutoCAD 2010/2011/2012
New Member
damian
Message 1 of 9 (747 Views)
Barcode image insert problem
747 Views, 8 Replies
10-22-2012 02:15 PM
Hi, I am currently working on a project which requires a barcode image to be attached to a drawing file. Ive been having problems where the barcode on the final drawing i print out does not scan.
The original barcode.bmp file if printed seperatly from paint for example, will scan perfectly. Only after i attach the barcode image into autocad and either print directly or print to pdf, the barcode will not be able to be scanned.
Is there maybe a import quality issue occuring or something else?
Thanks in advance.
Damian.
Alfred.NESWADBA
Message 2 of 9 (736 Views)
Re: Barcode image insert problem
10-23-2012 01:37 AM in reply to: damian
I don't see the image so I can't say if it's a quality problem, but my first thought was it may be a scaling problem. A barcode has to have specific lineweights and if you plot it with a scaling out of the tolerance it may fail.
If you had luck with printing it from paint then try to get the output from AutoCAD in the same size like you got it from paint and try again to scan it.
Another option might be if you have a bitonal image: in that case the color is modified by AutoCAD (by default the image-pixel will get the layer-color then). If that is not really deep black some scan-engines also fail evaluating the code.
- alfred -
Alfred NESWADBA
New Member
damian
Message 3 of 9 (720 Views)
10-23-2012 02:14 PM in reply to: Alfred.NESWADBA
Thanks for your reaply it was helpful.
I had just figured out the problem last night. Insted of inserting the image under insert/attach. I copied the image (ctrl+c) and then used the paste special command and selecting "Device Independant Bitmap". This seemed to work perfectly.
Thanks again.
Damian.
New Member
eqwqwqeqwe
Message 4 of 9 (571 Views)
05-20-2013 12:17 AM in reply to: damian
here is a image barcode add on dll source code in c# , you can have a try to see if it is the solution for your problem.
New Member
hongdida
Message 5 of 9 (521 Views)
06-03-2013 08:57 PM in reply to: eqwqwqeqwe
New Member
cristinsew
Message 6 of 9 (447 Views)
07-12-2013 02:47 AM in reply to: eqwqwqeqwe
Here is my suggestion: C# barcode generator libray. Try this tool to see if it is the problem of the barcode generator.
cindy313
Message 7 of 9 (345 Views)
10-29-2013 11:19 PM in reply to: eqwqwqeqwe
good resource you shared! i found what i want
JGerth
Message 8 of 9 (327 Views)
10-30-2013 10:03 AM in reply to: cindy313
there are also barcode fonts.....  typing in a number is a whole lot simpler than dinking around with images or pseudo images.
cindy313
Message 9 of 9 (240 Views)
01-13-2014 11:34 PM in reply to: JGerth
thank you ! i prefer the simpler one !
