I know this question will speak volumes about my cluelessness but I've been putting together a large drawing for submittal, 10 tabs and there are various logos and background images in it. Finally I got it to perfection and then backed up my computer and renamed the main directory (I always add the date it was backed up to the name) and then went to open my drawing and all images/logos are gone ... saying this is painful is an understatement ... 2 questions:
1. is there ANYTHING I can do to reverse what happened and get my drawing back without having to do a ton of work reinserting images/logos???
2. to avoid this in the future is there a command I can use to make the images/logos a permanent part of the drawing so that when I backup my computer this won't happen again??
thanks
Easy fix is to return the directory name to it's original name.
Not so easy fix is to repath all of the images you referenced and path them relatively.
Basically what you have done is told all if your images to take the left fork in the road at the tree near the red barn and then you removed the tree and red barn.
@Anonymous wrote:renamed the main directory (I always add the date it was backed up to the name) and then went to open my drawing and all images/logos are gone ...
AutoCAD can't find the images because you changed the path to the files. You will either have to re-path all the images, or change the directory name back so the files are where AutoCAD expects them to be. Obviously, the 2nd is easier.
In the future, I would suggest renaming your backup directory, not your working directory.
Keep the images in the same folder as the drawing.
Why are you changing the name of the current directory and not the backup at the time of backup?
Same-folder is not always the best path when the referenced material requires some management e.g. several hundred images and XREFs.
For the OP, have a look at the Reference Manager. Its installed along with AutoCAD, and provided you didn't change file names you can use it to modify search paths for referenced files in drawings. Alternatively, if your reference material is in the same drive and relativley close to the same folder, look into relative paths. These can save a lot of time when moving files between host folders. Finally, look into the PROJECTNAME system variable and the Project Files search path in the Options dialog. These can save time if you have to hop around between projects with wildly differing XREF paths.
the old saved path should show up in the XRef manager dialog.
As for burying the reference or images into the drawing -- bad choice. Doesn't work well and creates future problems.
To avoid in the future, Do Not Rename the working directory, including ANY portion of the path name from the drive letter on down. Instead, if you want to maintain dated folder names as an archive, copy or eTransmit you working draings to a separate, date-named folder
"Instead, if you want to maintain dated folder names as an archive, copy or eTransmit you working draings to a separate, date-named folder" - thank you very much for answering can you elaborate a little bit on this part and explain what you mean? as in give me an example or describe the steps so I get it? Thank you
thanks
is it possible to simply edit the "saved path" in the external references area for the images? I am attempting that now and don't see a way ...
