We have posted at:
http://forums.autodesk.com/t5/AutoCAD-Structural-Detailing/acaddoc-lsp-virus/m-p/4418111#M3061
I thought I'd post this again under a separate subject to highlight the specific virus names that my scan is naming.
Essentially we have tired the solution that Autodesk has proposed at:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=13717811&linkID=9240617
This has not helped.
Does anyone have a solution that works?
in the other thread you got an answer, but you didn't react on that, instead you created a new thread?
- alfred -
If you follow the link to my other post you'll notice that the "solution" we found did not work and was not a solution at all. I have not seen any posts for what our virus scan is naming this problem (w32/Bursted.L and ACAD/Bursted.I) so I started the new post and linked to the last one.
I appologize if this is not the proper protocol, but this is a vexing problem and I thought I'd try to cast a wider net.
Another solution was posted as a reply to another thread:
http://forums.autodesk.com/t5/AutoCAD-Structural-Detailing/acaddoc-lsp-virus/m-p/4418163#M3062
I have not tried this yet. I will update once we have given this a shot.
