AutoCAD 2010/2011/2012
New Member
Jude27
Message 1 of 4 (13,928 Views)
Autocad on surface pro
13928 Views, 3 Replies
06-15-2013 12:38 AM
Hi everyone. Just wondering if anybody uses autocad on their surface pro? Is it reasonable at everything? Does it seem slower than it should be? And would it be better to choose a laptop for the same price over the surface? Thanks guys,
Valued Mentor
TerryDotson
Message 2 of 4 (13,913 Views)
Re: Autocad on surface pro
06-15-2013 11:09 AM in reply to: Jude27
One consideration is that the Surface Pro is Windows 8 and only AutoCAD 2014 is certified to be compatible.  Running any previous version may present problems (display, fonts, open file dialog, etc)..
I run 2014 on a Surface Pro 128 and it works well.  If you don't plan on detaching the keyboard and using the Surface like a tablet, you are just as well off with a laptop (running Windows 7) for your situation.
*Expert Elite*
pendean
Message 3 of 4 (13,825 Views)
06-18-2013 06:16 AM in reply to: Jude27
There are quite a few blogs on the topic of touchscreens and AutoCAD if that's what you are really going after explore it here http://forums.autodesk.com/t5/The-Break-Room-Non-Technical/Touch-Screen-Interface/m-p/3927749/highli...
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Active Contributor
drspringer
Message 4 of 4 (1,463 Views)
08-30-2014 04:06 PM in reply to: TerryDotson
Terry,
How did you get it to run on the Surface. I just installed it on a Surface pro 3 and when I try to run it I get "This application was unable to start correctly"
I'm considering purchasing a Surface but only if I can get it to run Inventor for on the road stuff.
Post to the Community
New Post
Need installation help?
