I am running AutoCAD LT 2011 on a high DPI display with an Intel HD 5000 graphics card. Despite adjusting resolutions and scaling settings, I am unable to get some of the dialog windows to have bigger text. Also, selecting items in those windows is not accurate. One example of such a window is Tools > Customize > Import Customizations.
Is there some secret sauce to male AutoCAD work better and buyable on high DPI displays?
what resolution does your display have?
Most important at all is that the font size in Windows should not be changed, the option to modify the text size for Windows elements (like 125% or150%) should not be used as then some dialogs have issues (not only AutoCAD ones).
If the menu text in AutoCAD is too small the only possibility I see is to reduce the screen resolution (and yes, I understand that this is not what you wanted to hear).
- alfred -
The resolution is 2160x1440 (Surface Pro 3). I have tried with lower resolution but that window simply does not change its size including the fonts. 😞
So if you reduce your screendisplay from 2160x1440 to 1080x720 you don't see a difference? If so I think we speak about different settings, reducing the number of pixels the display has means automatically to have larger or smaller icons and text.
Can you show screenshots of both resolutions with the windows where you change it?
- alfred -
Sorry for the delay. After trying many different things including scaling and resolution and text size adjustments, we concluded that AutoCAD simply does not work with HiDPI displays.
We are giving up on it and moving on. 😞
