AutoCAD 2010/2011/2012
Member
0 Kudos
Post 1 of 14
AutoCAD LT 2011 suddenly refusing to start
1908 Views, 13 Replies
09-28-2012 08:34 AM
I work for a small architecture firm.  We use AutoCAD LT 2011, which has been installed on my system for about 18 months.  I finished work last night and saved and shut down normally, but this morning when I got in AutoCAD is suddenly refusing to start.  The error message I get is:
"Unable to run AutoCAD LT 2011.  This may be due to one of the following reasons:
1) This version of AutoCAD LT was not installed properly.  In this case you may wish to reinstall AutoCAD LT
2) You do not have sufficient rights to run AutoCAD LT"
So far, I've tried:
-A total reinstall of AutoCAD.  I uninstalled all autodesk products (design review, autocad and the materials library) and manually deleted the autodesk folders in the various appdata folders before reinstalling.  Same error.  Tried this twice.  The second time I made sure to set the install folder to something different and had it do the autocad SP1 updated while installing, but neither worked.
-Uninstalled and reinstalled the.NET framework.
-Rolled windows back to a previous restore point (two days ago).
-Created a new admin account in windows and tried running it under that.
Nothing has worked.  My only antivirus is windows security essentials, which I shut off while trying all this.  Short of totally nuking the windows install and starting over, I'm sort of at a loss as to how to fix this.  Everything else on the computer (outlook, internet, network folders, office, etc) all work perfectly normally.  The only thing that isn't working is AutoCAD.
Has anyone run across this before?  How did they solve it?
1,605 Kudos
Post 2 of 14
Re: AutoCAD LT 2011 suddenly refusing to start
09-28-2012 11:20 AM in reply to: ChrisJMAA
This seems to be a recent phenomenon, look around where you are posting for almost exactly the same issue. Explore their solutions and see if any help.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
0 Kudos
Post 3 of 14
10-01-2012 05:35 AM in reply to: pendean
I appreciate the response.  I have found several other instances of people having this issue, unfortunately the only offered solutions seem to be "do a clean uninstall and reinstall of AutoCAD" and "reinstall .net", both of which I've tried multiple times to no avail.  I've seen no concesus as to what causes the issue either.  All I know is it seems to be an AutoCAD/Autodesk specific problem, since all other software on the computer works perfectly fine (including software that uses .net).
Anyone else?  I'm at the point where all I can think of is to nuke the entire windows install and start over, which seems drastic to solve an AutoCAD issue, but I simply can't think of anything else to do.  :/
601 Kudos
Post 4 of 14
10-01-2012 05:58 AM in reply to: ChrisJMAA
Unplug the network cable, restart your PC, start autocad.
Try that
Member
0 Kudos
Post 5 of 14
10-01-2012 06:20 AM in reply to: ChrisJMAA
Thanks for the response.  Unplugging the network didn't work.
601 Kudos
Post 6 of 14
10-01-2012 06:35 AM in reply to: ChrisJMAA
Something stuck in the Windows Registry. After uninstall Autocad, go to registry (REGEDIT) and remove anything that has the word Autodesk in it.
If that can not fix it, buy another hard drive or format your HD.
Member
0 Kudos
Post 7 of 14
10-05-2012 06:30 AM in reply to: ChrisJMAA
Just as a follow up for anyone with the same issue, after trying everything people recommended with no results, I ended up reformatting and doing a clean install of windows and AutoCAD.  A tremendous pain, but it did work.
Hopefully other folks have better luck than I did getting things working without needing the nuclear option.
601 Kudos
Post 8 of 14
10-05-2012 06:42 AM in reply to: ChrisJMAA
Been there, that stubborn autocad,  but then it feel like a brand new machine.
New Member
0 Kudos
Post 9 of 14
02-08-2013 05:32 AM in reply to: ChrisJMAA
I fixed this by doing the following;
1. Launch Services (in the Start Search bar or a Run command enter: services.msc, or go to Control Panel > Performance/System and Maintenance > Administrative Tools > Services)
2. Locate and stop the Windows Presentation Foundation Font Cache 3.0.0.0 service
3. Delete "FontCache3.0.0.0.dat" from:
%windir%\ServiceProfiles\LocalService\AppData\Local
4. restart that service
Start up AutoCAD.
Hope this helps:-)
0 Kudos
Post 10 of 14
03-07-2013 10:29 AM in reply to: ChrisJMAA
Very same situation here. Just uninstalled everything (Autodesk, .NET), cleaned up, re-installed, etc. That was my third attempt, this time slowly, step-by-step,...
Still not working. :smileymad:
I guess the only way will also to wipe out and re-install the machine. ****!... I hope that'll work...
