AutoCAD 2010/2011/2012
Member
AndyMumm
Message 1 of 6 (698 Views)
AutoCad LT 2011 frozen when starting
698 Views, 5 Replies
09-28-2012 10:13 AM
One of the computers that have AutoCad installed will not load all the way.  It will start to show the welcome screen and the it will freeze.  Looking on the internet they suggest that you go into task manager and kill the process called WSCommCntr, but it is not appearing in the task manager.
Originally the pc was on XP SP2 and with .Net 3.5.  I updated both to the latest version.  I have reinstalled AutoCad and I am still getting the issue.  All harware checks passed.
Also the issue sounds just like the one here http://forums.autodesk.com/t5/AutoCAD-2011/AutoCAD-freezing-on-boot-in-student-lab/td-p/3626436 , but I uninstalled the .Net Framework and reinstalled version 3.5 SP1.  That did not work so I uninstalled that and put on 3.5.  This still is not working.
Any ideas?
If it helps my Service Request Number: 07672759
Edit: Also I am not getting an error message
Edit: Attached a screen shot of the issue
pendean
Message 2 of 6 (686 Views)
Re: AutoCad LT 2011 frozen when starting
09-28-2012 11:18 AM in reply to: AndyMumm
If all else fails, or any other suggestions offered do not work, explore these Autodesk recommended uninstall/reinstall procedures
Uninstall: http://usa.autodesk.com/getdoc/id=TS45252
Reinstall (for XP/Vista users): http://usa.autodesk.com/getdoc/id=TS75218
Ensure the user installing/uninstalling and using the product have enough rights to do so (install and reinstall as local administrator):
Unable to run AutoCAD® as a restricted user http://usa.autodesk.com/getdoc/id=TS1055299
If needed, test with another user profile as well.
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
AndyMumm
Message 3 of 6 (680 Views)
09-28-2012 11:28 AM in reply to: AndyMumm
Uninstalled and installed per the instructions and still nothing.
I am an admin on the domain so there aren't and rights to conflict during the installation.
Alfred.NESWADBA
Message 4 of 6 (666 Views)
09-28-2012 11:45 AM in reply to: AndyMumm
two additional options to try:
  • a) disconnect your workstation from network (and so also from internet)
  • b) login with another user-name (another Windows-account)
- alfred -
Alfred NESWADBA
Member
AndyMumm
Message 5 of 6 (623 Views)
10-01-2012 11:07 AM in reply to: Alfred.NESWADBA
Off the network still doesn't work.  (I assume you are checking to see if it is freezing trying to pull updates for the home sscreen)
Different user accounts:
User (non admin)
Me (admin)
Other IT (admin)
none of the above user acounts work.
Member
AndyMumm
Message 6 of 6 (565 Views)
10-08-2012 12:57 PM in reply to: AndyMumm
To fix the issue I built a new machine and installed AutoCAD.
It would've been nice to get this resolved with the old pc.
