AutoCAD 2010/2011/2012
*Expert Elite*
Message 11 of 36 (956 Views)
Re: Autocad gives the wrong area for a polyline
04-05-2011 11:45 AM in reply to: mmcmanus
Area changes if the pline is moved far enough from the origin.  Attached drawing shows 2 exact plines with different reported areas.  That is retarded.
*Pro
nestly
Message 12 of 36 (954 Views)
04-05-2011 11:47 AM in reply to: mmcmanus
mmcmanus wrote:
Interesting. I checked on 3 different machines with 3 different verticals (AutoCAD 2011, Map 3d 2011, and Civil 3D 2011) and got the same numbers each time. I wonder why it is different on your setup?
What's the area on your system if you move the pline in the original drawing to 0,0?
Member
whispering
Message 13 of 36 (931 Views)
04-05-2011 11:39 PM in reply to: whispering
I moved the same polyline around and got at least 3 different area values.
I'm using:
AutoCAD 2011 (with an extension)
Intel i7
Win XP pro, SP3 (32bit)
Units set to decimal/ precision 0
*Expert Elite*
pendean
Message 14 of 36 (910 Views)
04-06-2011 06:23 AM in reply to: ToanDN
Opened your file, zoomed in and used AREA>Object on both outlines. The results returned identical:
Command: z
ZOOM
Specify corner of window, enter a scale factor (nX or nXP), or
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>:
Specify opposite corner:
Command: aa
AREA
Specify first corner point or [Object/Add area/Subtract area] <Object>: e
Select objects:
Area = 308521556, Length = 159779
Command: z
ZOOM
[All/Center/Dynamic/Extents/Previous/Scale/Window/Object] <real time>: p
Command: aa
AREA
Select objects:
Then I copied the top most and dragged it even further away from 0,0,0, panned and then used AREA>Object: same result.
Command: co
COPY
Select objects: Specify opposite corner: 1 found
Select objects:
Current settings:  Copy mode = Multiple
Specify base point or [Displacement/mOde] <Displacement>:
Specify second point or [Array] <use first point as displacement>:
Specify second point or [Array/Exit/Undo] <Exit>: *Cancel*
Command: p
PAN
Press ESC or ENTER to exit, or right-click to display shortcut menu.
Command: aa
AREA
Select objects:
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Distinguished Contributor
mmcmanus
Message 15 of 36 (893 Views)
04-06-2011 10:00 AM in reply to: ToanDN
OK, Today I tested this and I am getting different area #'s. I did a 2nd test with just a 10x10 square also. I drew the square @0,0 and got the correct area and then I copied it to a random point 10,000,000 units from the original and got an area of 64 instead of 100.  Very strange.
mmcmanus
Message 16 of 36 (890 Views)
04-06-2011 10:08 AM in reply to: mmcmanus
OK, I give up. I just tried to recreate the error using a new drawing and the same 10x10 square and it calculated the areas correctly both times. This must be some kind of a random bug issue. Anyone have any ideas?
*Expert Elite*
Message 17 of 36 (882 Views)
04-06-2011 11:07 AM in reply to: pendean
Thanks for the workaround but I think you are missing the point of this thread.
Valued Contributor
bodhran
Message 18 of 36 (869 Views)
04-06-2011 08:51 PM in reply to: whispering
Hi guys,
Had a similar issue last week, a closed polyline far far far away from the origin, returned a zero area, moved closer to the origin gives the correct area.
It's a little scary as were using these area and there maybe legal ramification if we get it worng!!
B
Member
whispering
Message 19 of 36 (820 Views)
04-14-2011 11:07 PM in reply to: whispering
Does anyone know if AutoDesk knows about this bug and is trying to do something about it? I tried finding a customer info number or email. But apparently they have non.
*Pro
nestly
Message 20 of 36 (815 Views)
04-15-2011 02:01 AM in reply to: whispering
I'm pretty sure they know because there have been many threads, but it never hurts to send feedback.  Make sure to include a link to this topic so they can reply here.
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
