AutoCAD 2010/2011/2012
troma
Message 31 of 36 (517 Views)
Re: Autocad gives the wrong area for a polyline
07-17-2012 02:38 PM in reply to: TerryDotson
Wait a min! Didn't you say
"The AREA command can return an invalid number, while the underlying API (Polyline Object .Area Property) returns the correct value."
I'm getting the wrong answer both ways in that example, unless I'm misunderstanding you?
Credit where credit is due! Give kudos or accept as solution whenever you can.
Distinguished Mentor
TerryDotson
Message 32 of 36 (512 Views)
07-17-2012 04:41 PM in reply to: troma
Unless you are using some form of programming language to obtain the Area property supplied by the API, you are not seeing it (the correct value).  For example this small LISP routine will dump the properties of an object, including the area.
troma
Message 33 of 36 (503 Views)
07-18-2012 05:50 AM in reply to: TerryDotson
I tried to use that lisp, I get:
Command: DUMP
Select Object: ; error: bad argument type: lentityp nil
Any ideas?
dbroad
Message 34 of 36 (496 Views)
07-18-2012 09:31 AM in reply to: troma
Try this (slight fix)
troma
Message 35 of 36 (494 Views)
07-18-2012 09:39 AM in reply to: dbroad
Thanks for the fix.
But have a look Terry, I'm still getting the wrong area:
New Member
mujibnurulla
Message 36 of 36 (357 Views)
Re: Autocad gives the wrong area for a polyline can be corrected
02-07-2013 01:40 AM in reply to: troma
What I found is that, copy the polyline amd move towards 0,0. List it, check with area command. I hope u may satisfy up to maximum extent.
