AutoCAD 2010/2011/2012
Valued Contributor
jarrad27
Message 1 of 9 (1,677 Views)
AutoCad freezing during file open process
1677 Views, 8 Replies
09-06-2011 04:20 AM
I am having issues with my computer completely freezing while performing a File, Open process. Let me try to explain this. I'm in drawing 1, I save it, then go to open drawing 2. Drawing 1 will save, the open file window pops up. With me so far? While navigating through the file directory tree, my computer freezes. I do not chose a file that freezes during opening. It is during the process of getting to the folder drawing 2 resides in, and then it freezes. This happens to me multiple times a day. Ctrl +Alt+Delete will not work. I have tried letting my computer sit, as you would with a program not responding, and it doesn't unfreeze. The only option I am left with is a hard reboot. The only other program I have running is my MS Outlook.
I have been back and forth with our IT person, and because he can't replicate the problem (after trying one file open), he can't figure it out, or doesn't want to.
I am running AutoCad 2012 with a Dell Precision T3500, 2.13ghz, intell xenon E5506 processor, and 4gb of RAM. After looking at the system requirements, and reading that 2012 needs a 3.0 or higher processor, could this be the route of my issue?
Thank you in advance for any help or suggestions. With a little luck, your responses will give me the ammo I need to battle it out with our IT person.
*Expert Elite*
Alfred.NESWADBA
Message 2 of 9 (1,676 Views)
Betreff: AutoCad freezing during file open process
09-06-2011 05:15 AM in reply to: jarrad27
does this open-problem only occur on network, only on a specific directory or does that also happen on local-harddisk-directories?
Do you also have such problems when you start MS-Word and navigate with the open-dialog to this directory? (try it 20 times, just to see difffernces in responding-time or hangup or ...)
- alfred -
Alfred NESWADBA
Ingenieur Studio HOLLAUS ... www.hollaus.at
Valued Contributor
jarrad27
Message 3 of 9 (1,675 Views)
09-06-2011 05:20 AM in reply to: Alfred.NESWADBA
It happens on both network and local drives. I will try MS word, although we are still using 2003 office. Thank you for your response.
Jarrad
*Expert Elite*
Alfred.NESWADBA
Message 4 of 9 (1,672 Views)
09-06-2011 05:26 AM in reply to: jarrad27
for an administrator I would look into background-processes and turn off (for a few days) as much as possible.
So for example any security-options like antivir, defender, local firewall, ...
Next could be to temporary create a new account so you can login to your pc/windows with another profile, just for making sure that there are no user-specific settung. An additional try could be to get local administrator-rights .... ok, in that case you must have a very nice admin ;=)
Good luck, - alfred -
Alfred NESWADBA
New Member
rreusch
Message 5 of 9 (1,385 Views)
Re: AutoCad freezing during file open process
03-26-2012 06:42 AM in reply to: jarrad27
JARRAD27,
Hi, I have an new upgrade just installed at work . we went from 2006 to 2012. It sounds like I am having the same problem with freezing that you were. It doesn't do it all the time, but happens 3-4 times a day.
Did you figure out a fix ?
thanks
*Expert Elite*
drjohn
Message 6 of 9 (1,377 Views)
03-26-2012 07:37 AM in reply to: rreusch
rreusch wrote:
JARRAD27,
thanks
Happen to be running Norton 360?  It is well known for not playing well with AutoCAD.  There is a fix on the Norton site.
HTH
DJ
New Member
rreusch
Message 7 of 9 (1,365 Views)
03-27-2012 08:50 AM in reply to: drjohn
DJ,
Thanks for the response.
I talked to IT, we are NOT running Norton virus protection.
Any other thoughts ?
Russ
Active Member
VERBarchitecture
Message 8 of 9 (567 Views)
08-15-2013 01:45 PM in reply to: jarrad27
This is happening to me as well.  i am running windows 8 through bootcamp on a mac.  it only happens after a do a windows update.  It is a huge waist of my time though.  Anyone have  fix?
Active Member
VERBarchitecture
Message 9 of 9 (566 Views)
08-15-2013 01:46 PM in reply to: VERBarchitecture
waste not waist..  hahahah
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
