AutoCAD 2010/2011/2012
Valued Contributor
jarrad27
Message 1 of 9 (1,648 Views)
AutoCad freezing during file open process
1648 Views, 8 Replies
09-06-2011 04:20 AM
I am having issues with my computer completely freezing while performing a File, Open process. Let me try to explain this. I'm in drawing 1, I save it, then go to open drawing 2. Drawing 1 will save, the open file window pops up. With me so far? While navigating through the file directory tree, my computer freezes. I do not chose a file that freezes during opening. It is during the process of getting to the folder drawing 2 resides in, and then it freezes. This happens to me multiple times a day. Ctrl +Alt+Delete will not work. I have tried letting my computer sit, as you would with a program not responding, and it doesn't unfreeze. The only option I am left with is a hard reboot. The only other program I have running is my MS Outlook.
I have been back and forth with our IT person, and because he can't replicate the problem (after trying one file open), he can't figure it out, or doesn't want to.
I am running AutoCad 2012 with a Dell Precision T3500, 2.13ghz, intell xenon E5506 processor, and 4gb of RAM. After looking at the system requirements, and reading that 2012 needs a 3.0 or higher processor, could this be the route of my issue?
Thank you in advance for any help or suggestions. With a little luck, your responses will give me the ammo I need to battle it out with our IT person.
Alfred.NESWADBA
Message 2 of 9 (1,647 Views)
Betreff: AutoCad freezing during file open process
09-06-2011 05:15 AM in reply to: jarrad27
does this open-problem only occur on network, only on a specific directory or does that also happen on local-harddisk-directories?
Do you also have such problems when you start MS-Word and navigate with the open-dialog to this directory? (try it 20 times, just to see difffernces in responding-time or hangup or ...)
- alfred -
Alfred NESWADBA
Valued Contributor
jarrad27
Message 3 of 9 (1,646 Views)
09-06-2011 05:20 AM in reply to: Alfred.NESWADBA
It happens on both network and local drives. I will try MS word, although we are still using 2003 office. Thank you for your response.
Jarrad
Alfred.NESWADBA
Message 4 of 9 (1,643 Views)
09-06-2011 05:26 AM in reply to: jarrad27
for an administrator I would look into background-processes and turn off (for a few days) as much as possible.
So for example any security-options like antivir, defender, local firewall, ...
Next could be to temporary create a new account so you can login to your pc/windows with another profile, just for making sure that there are no user-specific settung. An additional try could be to get local administrator-rights .... ok, in that case you must have a very nice admin ;=)
Good luck, - alfred -
Alfred NESWADBA
New Member
rreusch
Message 5 of 9 (1,356 Views)
Re: AutoCad freezing during file open process
03-26-2012 06:42 AM in reply to: jarrad27
JARRAD27,
Hi, I have an new upgrade just installed at work . we went from 2006 to 2012. It sounds like I am having the same problem with freezing that you were. It doesn't do it all the time, but happens 3-4 times a day.
Did you figure out a fix ?
thanks
drjohn
Message 6 of 9 (1,348 Views)
03-26-2012 07:37 AM in reply to: rreusch
rreusch wrote:
JARRAD27,
thanks
Happen to be running Norton 360?  It is well known for not playing well with AutoCAD.  There is a fix on the Norton site.
HTH
DJ
New Member
rreusch
Message 7 of 9 (1,336 Views)
03-27-2012 08:50 AM in reply to: drjohn
DJ,
Thanks for the response.
I talked to IT, we are NOT running Norton virus protection.
Any other thoughts ?
Russ
Active Member
VERBarchitecture
Message 8 of 9 (538 Views)
08-15-2013 01:45 PM in reply to: jarrad27
This is happening to me as well.  i am running windows 8 through bootcamp on a mac.  it only happens after a do a windows update.  It is a huge waist of my time though.  Anyone have  fix?
Active Member
VERBarchitecture
Message 9 of 9 (537 Views)
08-15-2013 01:46 PM in reply to: VERBarchitecture
waste not waist..  hahahah
