AutoCAD 2010/2011/2012
Moderator
natanworking
Message 1 of 3 (471 Views)
AutoCAD Freeze when displaying a Browse Dialog Box
471 Views, 2 Replies
09-23-2011 03:21 PM
Hi there!!
I have some issues with AutoCAD 2010, Service pack 2 @ 64 bits, Working on Windows 7 SP1 @64 bits...
1. Open AutoCAD without any trouble
2. Press OPEN or NEW or any command that shows a File Dialog Box.
3. AutoCAD freeze. I must close it from Windows Task Administrator.
Obviously it is NOT the FILEDIA or something like that. Another thing... if I open a file directly from the Windows Explorer, it opens without any trouble. But if I try to insert (by example) a block using INSERT command and select Browse (It must open an File Dialog Box) AutoCAD freeze too.
Thanks for the support.
Natán Villarreal
http://cadworking.blogspot.mx/
Alfred.NESWADBA
Message 2 of 3 (456 Views)
Betreff: AutoCAD Freeze when displaying a Browse Dialog Box
09-24-2011 01:31 AM in reply to: natanworking
try to set FILEDIA to 0, can you then open files by typing the filename into the command-area?
Well I know, that's not called "solution", but should be tried to isolate the problem.
And if your admin is near you, he can give you administrator-rights for a few minutes, try it as admin.
Also you can try to login to your computer with another user-account, does it happen also with this user?
And if nothing helps I would do an installation-repair.
- alfred -
Alfred NESWADBA
Moderator
natanworking
Message 3 of 3 (448 Views)
09-24-2011 10:07 AM in reply to: Alfred.NESWADBA
Thanks Alfred, but I've tried (and find) a solution by a different way...
Actually FILEDIA let me open and save by Command Line, but as you comment, it's not a solution.
I am the administrator, but tried with another user, getting the same results.
Fortunately I could find an adequate solution without reinstalling the software. I could find that there were conflicts with Norton 360 Ver 5. When I uninstall Norton 360, everything works well. In fact, there is documentation about troubles between Norton 360 and AutoCAD, even there is a hotfix, but it only works for Norton 360 Ver 3.
Looks like the trouble has been solved. I hope this experience could help someone else.
Greetings!!
Natán Villarreal
