AutoCAD Forum
autocad error automation error drawing is busy
4 REPLIES 4
asim6687
4393 Views, 4 Replies
Dear All,
I am facing the problem of Lost a the work and File is become empty while the error is coming autocad error automation error drawing is busy, after this error the data is disapper from the file and even the back file is also become empty its happened many and I am losing me efforts which I have done from long time work.
Kindly give me a solution for this problem.
Naveed Akhtar
4 REPLIES 4
pendean
in reply to: asim6687
al_boreny
Dear Sir I have found very simple solution for the automation issue however it is required to have another PC without the same this error go to C:\Program Files\Autodesk\AutoCAD 2013 copy the support folder from this directory from the good PC take it to the PC which is facing the automation error paste it on the same directory C:\Program Files\Autodesk\AutoCAD 2013 it will ask to replace the file which already exist, select ok and replace the folder congratulation the error is no longer exist i have tried that on my PC and it is working fine however make sure that the support folder which you copy it is from a PC with no old records for this issue Regards Faisal AG
abrahambale
naffah
”Boost
