Hi guys,
I have a problem with explode command, because I want to explode a block with attributes without losing them. In Autocad 2007 I used to type in "burst" but in this version this command doesn't exist. Anyone can solve this problem?
Henrique.
Burst is an express menu command, did you install it with your autocad package? if yes, try to use the explode attribute to text from the express menu, if it works check the command line to see what the command is. I have the command on a machine with ACAD Elec 2014.
I've read a tutorial explanning the instalation process of the express tools, but it didn't work for me. I tryed to load the expression tools by accessing the control panel and clicking on “Programs and Features” then "Uninstall/change". I clicked on "Add or Remove features" but there isn't the option "Express tools" in the check list. Can I download it?
Ps.: I am using the student version of Autocad 2013.
Thanks for yours comments.
Henrique.
