AutoCAD Forum
AutoCAD crashes on startup 2012-2014
5 REPLIES 5
1808 Views, 5 Replies
Hi Autodesk Forums!
I have this subject in school where we're supposed to be using AutoCAD for educational use. I had heard that you could get it for free if you are a registered student. I then proceeded to downloading AutoCAD and I went with 2014, however, when I had it installed and ran it, it came up with the following message:
"FATAL ERROR: Unhandled Access Violation Writing 0x006c Exception at de4efe0bh"
I thought, that maybe it was because my computer couldn't handle AutoCAD '14 since I only have Windows 7.
I went on and downloaded AutoCAD '13, but I still got that message. I even tried with AutoCAD '12 but it still gives me the same message.
I don't know if this is of any use, but my here are my computer specifications:
  • Intel Core 2 Duo T6600 2.2 Ghz
  • nVidia Geforce GT 130m
  • 4 GB DDR2 800MHz ram
  • Windows 7 Home Premium SP 1
I hope someone can help me out as I need to use AutoCAD for the rest of the year.
- Morten
5 REPLIES 5
Charles_Shade
Welcome to the Autodesk Forums!
First of all:
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
Turn off any running Virus protection you may have for the new install.
(I'm a little fuzzy on this - DEP Protection may be an issue for the install as well. This can be turned On/Off from right clicking the Desktop icon)
Run the program as an Adiministrator for the first time on your System.
Secondly:
Is this where you are downloading the Student Versions?: http://students.autodesk.com/
Interesting that you can get the older Software versions as well. Kudos Autodesk
Thirdly: (May be needed)
.NET Cleanup Utility:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
braudpat
in reply to: Charles_Shade
Hello
+1 with Charles
1 - Please install as LOCAL ADMIN
2 - RUN as LOCAL ADMIN
then if OK , Reboot, Install Services Packs
Re-RUN as LOCAL ADMIN
3 - Then if OK , Test with the Normal Login ...
Bye, Pat
Patrice ( Supporting Troops ) - Autodesk Expert Elite
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Felicitations) - Thanks
Patrice BRAUD
dgorsman
Fourth: since the OP doesn't mention whether the Win7 OS is 32-bit or 64-bit, the installer must match.  If this is 64-bit, 4 GB RAM is a little short, even for educational purposes.  Try to get another 4 GB in there if possible.
If you are going to fly by the seat of your pants, expect friction burns.
"I don't know" is the beginning of knowledge, not the end.
in reply to: dgorsman
Yeah, forgot to mention that.
My system is 64-bit but I won't spend cash on this laptop. Only got one year left of school, so.
And to answer your second question.
Yes, they offer 10 year old versions of AutoCAD. I think it's pretty nice. 🙂
”Boost
