Hi Autodesk Forums!
I have this subject in school where we're supposed to be using AutoCAD for educational use. I had heard that you could get it for free if you are a registered student. I then proceeded to downloading AutoCAD and I went with 2014, however, when I had it installed and ran it, it came up with the following message:
"FATAL ERROR: Unhandled Access Violation Writing 0x006c Exception at de4efe0bh"
I thought, that maybe it was because my computer couldn't handle AutoCAD '14 since I only have Windows 7.
I went on and downloaded AutoCAD '13, but I still got that message. I even tried with AutoCAD '12 but it still gives me the same message.
I don't know if this is of any use, but my here are my computer specifications:
I hope someone can help me out as I need to use AutoCAD for the rest of the year.
- Morten
Welcome to the Autodesk Forums!
First of all:
Autodesk Recommended Clean Install Procedure:
http://usa.autodesk.com/adsk/servlet/ps/dl/item?linkID=9240817&id=2887771&siteID=123112
Turn off any running Virus protection you may have for the new install.
(I'm a little fuzzy on this - DEP Protection may be an issue for the install as well. This can be turned On/Off from right clicking the Desktop icon)
Run the program as an Adiministrator for the first time on your System.
Secondly:
Is this where you are downloading the Student Versions?: http://students.autodesk.com/
Interesting that you can get the older Software versions as well. Kudos Autodesk
Thirdly: (May be needed)
.NET Cleanup Utility:
http://forums.autodesk.com/t5/Installation-Licensing/NET-Framework-Cleanup-Tool-for-Unhandled-Except...
Regards, Charles Shade
CSHADEDESIGN | AUTOCAD LT | LT-KB | DYNAMIC BLOCKS
Please mark Accept as Solution if your question is answered. Kudos gladly accepted. ⇘
Hello
+1 with Charles
1 - Please install as LOCAL ADMIN
2 - RUN as LOCAL ADMIN
then if OK , Reboot, Install Services Packs
Re-RUN as LOCAL ADMIN
3 - Then if OK , Test with the Normal Login ...
Bye, Pat
Patrice BRAUD
Fourth: since the OP doesn't mention whether the Win7 OS is 32-bit or 64-bit, the installer must match. If this is 64-bit, 4 GB RAM is a little short, even for educational purposes. Try to get another 4 GB in there if possible.
Yeah, forgot to mention that.
My system is 64-bit but I won't spend cash on this laptop. Only got one year left of school, so.
And to answer your second question.
Yes, they offer 10 year old versions of AutoCAD. I think it's pretty nice. 🙂
