Dear Friends
I use Architecture 2011 and in 2 occasions I have my laptop frozen and nothing moves or works even ‘control Alt delete’ doesn’t work. It happened in both 2D and 3D sessions.
Background info
I installed the 2 updates available, update-1 and update 2
I do have latest driver for NVIDIA installed
The laptop is Asus ROG G750JM one of the latest laptops in the market, ‘ROG = Republic of Gamers’ I use for architecture not games.
I did not got any error window or notes to share with you, laptop freezes and no functio works
Only remedy to make laptop work again is shut down and restart
I do have second laptop Toshiba Qosmio 18.4” screen, which works brilliantly no freezing, no problems for last 2 years. Also top laptop with Intel i7 processor, I checked many settings and suggestion on the net to see if one laptop has different setting, but both laptops has similar settings.
My problem is not at the start as noted in many other postings but laptop freezes at middle of normal session 1hour or 1.5 hour into the normal working. So problem not at the start.
The OS is Wiindow-7 Ultimate 64bit, with Service Pack-1
I wonder if anyone faced similar issues and found a solution.
Thanks Alex
>> on a brand new high powered Antec desktop
What are the specs of that workstation, especially operating system and graphic card.
And is it exactly the same as the TO stated "to make laptop work again is shut down and restart" so you can't move the mouse, you can't start taskmanager by <ALT><CTRL><DEL>?
- alfred -
