Hi ,
I have a Valid working Autocad 2012 installed in my old computer.I have got a New computer and want to use Autocad 2012 on this computer and transfer it here. I have checked the Transfer utility , but i cannot find any link to downlod Autocad 2012 for 64 bit ??
Should I use the tranfer utility without downloading autocad on new system ?
-Shivam
when you got AutoCAD 2012 you should have got 2 DVD's, one for 32bit, the other for 64bit.
If you don't find it, you can search >>>here<<< and select Download links ==> AutoCAD products ==> AutoCAD ==> ... on the right side to find your download.
- alfred -
Unless you are on subscription and you did not opt in for physical media shipment.
...in which case you should have, of course, burnt your own backup install disks.
When (if) you get the install files again - be sure to do this.
@shivamnigam9 wrote:Hi ,
-Shivam
