AutoCAD 2010/2011/2012
New Member
amkot1
Message 1 of 3 (3,361 Views)
Autocad 2012 will not load hangs on acmgd.dll
3361 Views, 2 Replies
08-26-2012 11:03 AM
The program hangs forever at the splash screen: "Loading plug-ins... acmgd.dll"
I'm running Windows 7, 64 bit.
It was working up until recently.
Tried to repair the file through the control panel, no dice.
Also updated to SP 2 to see if that would fix it. nothing.
Tracked down the machine.configure files in the .NET directory to make the changes suggested in another fix. Still nothing.
I'm unwilling to re-install windows entirely, and reinstalling Autocad hasn't seemed to help anyone.
I've considered replacing the .dll in the directory, but would it help? and does anyone have a reliable download source?
Also - Revit seems to be suffering from the same problem.
Alfred.NESWADBA
Message 2 of 3 (3,358 Views)
Re: Autocad 2012 will not load hangs on acmgd.dll
08-26-2012 11:17 AM in reply to: amkot1
have you found >>>that info<<< about hangup while splashscreen showing? Try it!
The other option may be that you use the option to reset the AutoCAD-profile (to be found in Windows start-menu ==> Autodesk-section ==> AutoCAD 2012 ==> there it is)
- alfred -
Alfred NESWADBA
dgorsman
Message 3 of 3 (3,338 Views)
08-27-2012 09:57 AM in reply to: amkot1
Stupid question time: which plug-ins have you added/installed?
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
