AutoCAD 2010/2011/2012
katie1994
Message 1 of 4 (1,970 Views)
autocad 2012 plot Shaded Viewport Options sketchy
1970 Views, 3 Replies
03-01-2012 10:31 AM
Can anyone tell me how to use the "Shaded Viewport Options" in the Plot dialog box? We saw an option for Sketchy in the dropdown menu but I can't find any information about how to use it, or how to change the settings, or even what the intent is for it. When we have selected it and viewed in Preview it shows up as a mass of lines too dense to be usable.
We are using AutoCAD 2012 on a PC in model space.
dgorsman
Message 2 of 4 (1,964 Views)
Re: autocad 2012 plot Shaded Viewport Options sketchy
03-01-2012 11:26 AM in reply to: katie1994
Check the Visual Styles palette, there's a boatload of settings there.  Most of them are documented in the Help file, and there are pop-ups on the palette (if enabled).  Those and a little experimental testing will hopefully get you close to what you are looking for.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
New Member
bsdoainvention
Message 3 of 4 (961 Views)
12-26-2013 10:15 AM in reply to: katie1994
Yes it is trouble!!! I want to print my layout at a realistic view and I canot!!!! As you see, there is the option "shaded vieport options" but it is grey and I can not select the option I want "As displayed" !!! Please can somebody help me and tell me how I can corect that option??? Thank you.
Be carefull
hmsilva
Message 4 of 4 (940 Views)
12-26-2013 01:23 PM in reply to: bsdoainvention
Hi bsdoainvention, welcome to the Autodesk Community!
- go to the layout
- select the layout boundary
- type PROPERTIES
- under Misc, Shade plot -> As Displayed
Hope that helps
Henrique
