AutoCAD 2010/2011/2012
Member
0 Kudos
Post 1 of 16
Accepted Solution
AutoCAD 2012 on Windows 8 Developer Preview
9303 Views, 15 Replies
12-02-2011 05:53 PM
i am running Windows 8 developer preview on my machine, as Windows 7 cannot boot with my specific bootloader method. The installation crashes before it can install the app. I have attached the dump files, and I have submitted these almost 5 times previously, and have not gotten any replies. Is there any way you can help me?
AutoCAD 2012 needs .NET 4.0. I'm guessing this is probably built into Windows 8. That's what Microsoft seems to do with each new version of Windows. You can run the acad.msi to install AutoCAD, which bypasses all the prerequisite checks and installs. It's in your install folder inside the \x64\acad folder.
*Expert Elite*
1,597 Kudos
Post 2 of 16
Re: AutoCAD 2012 on Windows 8 Developer Preview
12-03-2011 05:50 AM in reply to: jpruim
You want support with an unsupported OS?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
0 Kudos
Post 3 of 16
12-05-2011 07:33 AM in reply to: jpruim
Actually, It's not truly a support issue, I am able to manually install any Autodesk app on it, and run it just fine, with the minor quirks because of something not being installed. I have managed to boil it down to (I think) the .NET 4 framework. Windows 8 has .NET 4.5 installed, so, is there any way to make the installer skip .NET 4?
New Member
0 Kudos
Post 4 of 16
03-05-2012 07:03 PM in reply to: jpruim
Just so you know Inventor installs just fine and runs great in Windows 8 beta....  It's the **** Windows Net Framework... coding that is not yet compatable there are several work arounds but AutoDesk needs to fix this....
shopdoug
Product Support
18 Kudos
Post 5 of 16
03-06-2012 03:55 PM in reply to: jpruim
Bryce Thelin
New Member
0 Kudos
Post 6 of 16
03-06-2012 08:24 PM in reply to: jpruim
Works great....  I had to create a fold insde the Autodesk folder as I had installed Inventor prior to installing AutoCAD....
Thanks for you help......
cadgodintraining
Product Support
18 Kudos
Post 7 of 16
03-07-2012 09:05 AM in reply to: jpruim
I'm glad to hear that worked! If you would, please mark my post as "Accept as Solution."
Bryce Thelin
New Member
2 Kudos
Post 8 of 16
03-10-2012 06:47 AM in reply to: jpruim
Yes.
What I did in the setup ini file is under "[DOTNET4]" and "[DOTNET4LANG]" I added:   "IGNORE_FAILURE=YES"
Look under "[DOTNET20]"  few lines below, you can copy it.
To me this way seems more "natural".
Worked like a charm, however i did use autocad mechanical so there might be a difference.
New Member
0 Kudos
Post 9 of 16
06-25-2012 09:53 PM in reply to: nxg1575
Thank you so much! I used your method to make 2013 CAD working on my Windows 8.
New Member
0 Kudos
Post 10 of 16
07-17-2012 07:27 AM in reply to: jpruim
Thank You Man!!! its perfect solution! Saludos desde argentina!!
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
