AutoCAD 2010/2011/2012
New Member
0 Kudos
Post 1 of 14
AutoCAD 2012 License
408 Views, 13 Replies
03-09-2013 04:18 AM
Here's my situation and what I'm trying to accomplish: Currently, we have 3 stand alone license's and are wanting to reinstall AutoCAD 2012 for a network for various reasons. I uninstalled and installed the tools/utilities for a network license file however I just have our 3 stand alone licenses. Can I not use them in a file to be distributed by the server? Please let me know. Thanks.
*Expert Elite*
62 Kudos
Post 2 of 14
Re: AutoCAD 2012 License
03-10-2013 01:27 AM in reply to: rweller423
Please note that a network license is not just a different type of installation - you will also need to obtain a different license from Autodesk. Please talk to your Autodesk dealer about a NLM upgrade.
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
*Expert Elite*
263 Kudos
Post 3 of 14
03-12-2013 01:44 AM in reply to: vladimir.michl
Hello
Switching from Standalone to Network (FlexLM) Install (and the Reverse),
you have to Un-Install and then Re-Install your ACAD software !
In the past, before ACAD 2010 (if I remember well), it was only a Key into the Register !!
Bye, Pat
Bye, Pat ( Supporting Troops )
If you are happy with my answer please mark "Accept as Solution" and if very happy please give me a Kudos (Compliment) - Thanks
*Expert Elite*
474 Kudos
Post 4 of 14
03-12-2013 07:20 AM in reply to: braudpat
braudpat wrote:
Hello
Bye, Pat
You should be able to go from standalone to network, but generally not the other way around. (If it does work the other way, you will be in 30-day demo mode)
See:
http://upandready.typepad.com/up_and_ready/2011/10/autocad-2012-hacking-the-registry-to-change-the-l...
and
http://www.citronix.net/blog/how-to-change-autocad-2012-from-a-standalone-to-network-license/
*Expert Elite*
263 Kudos
Post 5 of 14
03-12-2013 07:28 AM in reply to: rkmcswain
Hello from France
Sorry, maybe I don't write/speak correct US/English ...
I have already switched from Standalone to Network to Standalone : no problem at all !
Of course my Standalone was authorized and with the Network version,
I could reach a FlexLM Server with available licenses ...
Bye, Pat
*Expert Elite*
474 Kudos
Post 6 of 14
03-12-2013 09:14 AM in reply to: braudpat
braudpat wrote:
Switching from Standalone to Network (FlexLM) Install (and the Reverse), you have to Un-Install and then Re-Install your ACAD software !
Yea, I'm a little confused. First you said you have to "Un-Install and then Re-Install"... Now you say that you have done it with "no problem at all"
*Expert Elite*
263 Kudos
Post 7 of 14
03-12-2013 09:43 AM in reply to: rkmcswain
Hello
Ok Sorry, I will try to write a better English ...
To switch from a Standalone ACAD 201X to a Network ACAD 201X
You have to Un-Install the Standalone ACAD, Reboot (Security !), Install the Network FlexLM ACAD
Don't forget the Service or Update Packs ?!
and idem if you switch from the Network FlexLM ACAD to the Standalone ACAD ...
Of course with the Standalone version you will have ONLY ONE 30 days Trial period !
As I said I have already switch several times for tests purposes on my PCs without any problem ...
Bye, Pat
*Expert Elite*
474 Kudos
Post 8 of 14
03-12-2013 11:22 AM in reply to: braudpat
So you are saying that the information in the links I provided is not true??
There are multiple comments on both of those articles saying it does work.
I have personally changed multiple seats from standalone to network licensing, although that was for 2007 and 2008 versions. I have not had the opportunity on anything recent.
*Expert Elite*
504 Kudos
Post 9 of 14
03-12-2013 11:44 AM in reply to: rkmcswain
I think 2008 was the last version you could do the registry trick.  More recent versions require a re-install, but with a properly built silent deployment its not that big a deal.
If you are going to fly by the seat of your pants, expect friction burns.
Adopt. Adapt. Overcome. Or be overcome.
A good question will be halfway to a good answer.
*Expert Elite*
263 Kudos
Post 10 of 14
03-13-2013 01:42 AM in reply to: dgorsman
Hello
I confirm that the trick with a register key (Switch Standalone <--> Network FlexLM)
has been terminated with approximatively ACAD 2010 ...
« HKLM / Software / Autodesk / AutoCAD / R16.x / ACAD-201-xxxx » ou 202-xxxx
AdLM = value 19 in Hexa (=25 Décimal) for Network FlexLM.
AdLM = value 2A in Hexa for Standalone "Classic"
I am very sad about this Autodesk decision !!
Bye, Pat
Post to the Community
New Post
Announcements
Are you interested in helping shape the future of the Autodesk Community? To participate in this brief usability study, please click here. Your time and input is greatly appreciated!
