Hey. I open a dwg file, scroll around in paper space, go to model space, scroll around, go back to paper space, and all of the lines are messed up. It's almost as if model space has merged with paper space and I'm looking through it. I can see exactly what I see in model space IN paper space along with the other stuff. Regen doesn't fix it. This glitch happens on every computer EXCEPT the computer the file was created on. Help is appreciated.
Thanks.
Solved by ITman22. Go to Solution.
Is the viewport in paper space locked or unlocked?
Post the file so someone can have a look at it.
Hey. I've attached the file with proprietary things removed and many lines deleted.
Thanks.
I've just opened your file and I do not have any problems zooming and panning in model and paper space.
I noticed that you have two circular viewports.
I never use circulat viewports but I undestand that these can sometimes be troublesome.
There are multiple files that have this same issue.
I'll look into the circular viewports idea.
All PCs are using 2012
I don't think it would be the xref.
Oh and I found out that 2 out of 4 computers can run the file without glitches. Weird.
Just FYI ... not a criticism... I use circular viewports daily and never had an issue with them.
DJ
can you upload a file plus the screenshot that shows the issue with this file so it's easier for us to compare your results with our's.
I would first try to disable hardware acceleration and see if that issue happens again.
If disabling the hw-acceleration solves the problem the next step is to find a graphic card driver working with your files with activated hw-acceleration.
- alfred -
I've attached the file. I can't get a screenshot right now because the people with the 2 computers that mess up are using their computers.
Thanks.
As others reported ... I don't see a problem with your drawings too ... that's why I wanted to see a screenshot (with markers which show the position of the ghost-objects). That can bring up other ideas.
But again, try the hw-acceleration, and let us know if that helped.
- alfred -
Hey. The hw-acceleration didn't help. I've attached a screenshot.
Could there be another (overlapping) Viewport?
Use CTRL+R to cycle through all the VP's and/or use QSELECT to verify how many Viewports exist.
Your 'garbage" look like smaller scaled versions of the viewport on the left and the viewport on the right. Where are those? Not in your posted file that you shared (nestly2's idea).
Advanced Steel proxy content is showing up in your file: could be your add-on that is the culprit. Here is your cleaned up file. Of that missing XREF?
My colleague just found the solution. It is: Options > System > Layout Regen Options > Regen when switching layouts. If it's set to Cache model tab and all layouts, then it has the glitch.
