AutoCAD 2010/2011/2012
Member
guitarchic0516
Message 21 of 32 (2,761 Views)
Re: AutoCAD 2012 freezes or lags when using the copy command
10-24-2011 07:58 AM in reply to: Jlasante
SORRY, Autodesk! After I saved my file and then opened it back up after filering the layer, the laggin was fixed!
New Member
RudyMartignago4984
Message 22 of 32 (2,596 Views)
11-23-2011 02:06 PM in reply to: guitarchic0516
I have a lagging problem when I select Layer Isolation 10sec each time. we are using V2012. Any suggestion?
New Member
MattConlin
Message 23 of 32 (2,409 Views)
01-09-2012 11:50 AM in reply to: Jlasante
I also had this problem.  It happened to me on two different computers, one had autocad LT 2012 , the other had autocad 2012.  I also had a bazillion layer filters, so I deleted them, and the lagging problem persists.
I'd love to find a solution to this.
New Member
MattConlin
Message 24 of 32 (2,407 Views)
01-09-2012 11:54 AM in reply to: MattConlin
I also should add that I notice the lagging in any type of copy related command such as array or mirror.
New Member
triple20
Message 25 of 32 (2,335 Views)
01-16-2012 08:47 AM in reply to: guitarchic0516
Try turning off the Dynamic UCS. (UCSDETECT change to 0, default is 1). It worked for me.
New Member
grantbgarner
Message 26 of 32 (1,800 Views)
05-11-2012 10:39 AM in reply to: Jlasante
Deleting extra layer fliters solved this problem for me.
Valued Contributor
xxmnbxxx
Message 27 of 32 (1,680 Views)
06-25-2012 01:36 PM in reply to: Jlasante
I have experienced the same issue. When I paste the cross hair freezes and the drawing crashes. That is the problem, now what is the solution.
Valued Contributor
xxmnbxxx
Message 28 of 32 (1,679 Views)
06-25-2012 01:39 PM in reply to: pendean
I find that extremely impossible to believe, ACAD 2011 and 2012 have been prone with MANY issues, I'm running WIN 7 64 bit anything less and you have snail CAD. Does Autodesk actually run their software in real world environment?
Just curious.
Valued Contributor
xxmnbxxx
Message 29 of 32 (1,679 Views)
06-25-2012 01:40 PM in reply to: Patchy
It is NOT RAM related. It is poor code related.
New Member
sandy_sandeep_1980
Message 30 of 32 (1,628 Views)
07-12-2012 09:37 PM in reply to: jaich
Hi. My self sandeep chauhan, I also faced the same problem in autocad 2012 when I try to copy clip something hatched.
I simply turn off the notification about the associative hatch, which pop up in upper right corner of autocad.
Hope this will work for you all also.
