AutoCAD 2010/2011/2012
Valued Contributor
vferrara
Message 1 of 7 (2,358 Views)
AutoCAD 2012 Crashing on 64 bit Workstations
2358 Views, 6 Replies
12-13-2011 08:51 AM
We are running AutoCAD Architecture 2012 on a Windows 7......64bit workstation and AutoCAD will suddenly crash for no apparent reason. When I look in the event log it makes a reference to the AcDB18.dll   has anyone seen this before....?? Is there a way to correct this problem....??
Thank you,
Vince
Valued Contributor
vferrara
Message 2 of 7 (2,281 Views)
Re: AutoCAD 2012 Crashing on 64 bit Workstations
12-15-2011 08:15 AM in reply to: vferrara
What can be done to resolve this....?
l.tucker
Message 3 of 7 (2,277 Views)
12-15-2011 08:22 AM in reply to: vferrara
Is there any error message on the screen? Are you all up to date on service packs and hotfixes (http://usa.autodesk.com/adsk/servlet/ps/dl/index?siteID=123112&id=2334435&linkID=9240618)?
Valued Contributor
vferrara
Message 4 of 7 (2,264 Views)
12-15-2011 09:07 AM in reply to: l.tucker
I believe we had Service Pack 1 installed.....!
When the crash occurs I get a message stating AutoCAD can not continue.....Exiting AutoCAD....!
When I look in the event log there is a reference made to the AcDB18.dll....?  which I do not know if is related to the reason AutoCAD crashed in the first place.
Vince
Patchy
Message 5 of 7 (2,259 Views)
12-15-2011 09:27 AM in reply to: vferrara
.dll sometimes can be corrupted
If you have another PC with same operating system, check for the size of the file.
New Member
reydelblues
Message 6 of 7 (1,934 Views)
03-21-2012 09:15 PM in reply to: vferrara
The same happened to me with the Autocad Architecture 2012 ,:smileymad:and I´ve made an experiment: Y crated a model using the new tools : walls, windows blablabla and the system was so cramped that I could´t make a line. Then I tried making the same model in the old fashion way (poliline, extrude, height...) and it run perfect... so in conclusion the new tools are unusefull
New Member
cbarnett
Message 7 of 7 (945 Views)
03-26-2013 01:31 PM in reply to: vferrara
I am running AutoCAD LT 2012 on Windows 7, 64 bit. Stops working after plot-save-close or plot-close.
Ran all available Service packs with actual executable files.
Am running as admiinistrator.
What's the deal?
