AutoCAD Forum
AutoCAD 2012 Copy/ Paste option NOT working
14 REPLIES 14
Message 1 of 15
pmora1
2640 Views, 14 Replies
When I try to copy and pate any element within the same drawing it won´t paste it will say: "specify insertion point" and I´ve given up.
I tried PICKFIRST but it is set to 1, also tried checking if it would fit in my screen or if the zoom was messed up, but nothing works!
14 REPLIES 14
Message 2 of 15
Patchy
in reply to: pmora1
List the objects you want to copy, what does it say?
Message 3 of 15
pmora1
in reply to: Patchy
same thing... "specify insertion point"
Message 4 of 15
Patchy
in reply to: pmora1
Never seen "specify insertion point" with "LIST" command.
LIST and pick the object, dialog box would pop up would tell you what it is.
Message 5 of 15
pmora1
in reply to: Patchy
... they are lines...
Message 6 of 15
pmora1
in reply to: Patchy
Double checked.... but it is only lines and dimensions
Message 7 of 15
Patchy
in reply to: pmora1
EXPORTTOAUTOCAD make a new drawing, open this new one and try copy/paste.
Message 8 of 15
pmora1
in reply to: Patchy
It tells me that it is an unknown command
do you this this is happening because I am using the trial version? should I reinstall the complete version?
Message 9 of 15
pmora1
in reply to: pmora1
think*
Message 10 of 15
Patchy
in reply to: pmora1
No difference with trial version. Attach your dwg here, let's see.
or use DXFOUT to ealier version 12 , DXFIN and try copy/paste again.
Message 11 of 15
pmora1
in reply to: Patchy
Still doesn't work 😞
Message 12 of 15
Patchy
in reply to: pmora1
Attach your drawing here let's find out why.
Message 13 of 15
pmora1
in reply to: Patchy
Wait I think I fixed it... or it never stoped working haha... it just pastes it on a different place, but still on the same drawing
Message 14 of 15
pmora1
in reply to: Patchy
it does paste the objects all the way to de right end of my drawing though... do you know why that is?
Message 15 of 15
jggerth
in reply to: pmora1
any of those dimensions radius?  if so, the extents of the selected objects will include the center node for the radius (or any other dimension nodes)  If you try CopyBasePoint instead of a simple <CTRL>C - can you place things where you want them?
”Boost
