AutoCAD 2010/2011/2012
Active Member
0 Kudos
Post 11 of 18
Re: AutoCAD 2011 crashes immediately
10-05-2010 12:25 PM in reply to: TravisNave
I tried that and still get the same result with the exact same error code as my previous post.
I have to say, I really appreciate the help, Travis. Thank you.
900 Kudos
Post 12 of 18
10-05-2010 12:30 PM in reply to: mtseng
That's pretty ridiculous at this point.  Those are generally all the tricks that get you past that error.  Worst case, remove all of those files completely and then reinstall.  It should think it is a fresh install at that point.
Active Member
0 Kudos
Post 13 of 18
10-05-2010 12:37 PM in reply to: TravisNave
Yes, it is ridiculous. Sorry to pass my frustrations onto you.
I will do my best to remove everything I can and try another fresh install. My biggest challenge is that I don't want to do anything that will jeopardize my 2008 install since it's the only thing I have operable at the moment. I only have a few more hours to play with this anyway and then I'm just going to have to bite the bullet and go back to 2008 and get caught up.
Again, thank you very much for your input. It is greatly appreciated.
900 Kudos
Post 14 of 18
10-05-2010 12:52 PM in reply to: mtseng
Well fortunately Autodesk changed the licensing scheme with the 2010 product, so only your 2010 and 2011 AutoCAD will not work. It should not affect your exising 2008 at all.  Autodesk is pretty good about keeping their products separated from each other.
New Member
0 Kudos
Post 15 of 18
06-23-2011 06:55 PM in reply to: mtseng
Noticed your posts and I am having very similar problems with Autcad LT2012.
Did you ever discover the fix?
Member
0 Kudos
Post 16 of 18
06-27-2011 05:58 AM in reply to: TravisNave
We had a machine that crashed.  After reboot all profiles of AutoCAD refused to open.  Deleteing the CascadeInfo.cas file worked for us.  Thanks alot
New Member
1 Kudo
Post 17 of 18
04-12-2012 04:00 AM in reply to: mtseng
hi friend have you problem same as problem is solved as follows
-uninstall autocad 2011
-erase C:\ProgramData\FLEXnet
-erase C:\ProgramData\Autodesk\Adlm
-install autocad 2011
and fix it
New Member
0 Kudos
Post 18 of 18
04-24-2012 05:21 PM in reply to: erglter
Thanks WORKED FOR ME :smileyhappy:
