AutoCAD 2010/2011/2012
Member
cdurb26003
Message 1 of 6 (15,760 Views)
AutoCAD 2011 (& 2010) FATAL ERROR: Unhandled Access Violation Reading ...
15760 Views, 5 Replies
08-11-2010 08:18 AM
If anyone would be able to assist me with the following problem, it would be most appreciated.
I'm trying to open a drawing file, and every time I do, I receive this message:
FATAL ERROR: Unhandled Access Violation Reading 0xd92123c2 Exception at 1675dc8h
The problem occurs on at least 2 machines, in either AutoCAD 2010 or AutoCAD 2011.
Both machines are running 32-bit XP Pro SP3 w/ 4GB RAM.
I attempted to follow the instructions here: http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=11322398&linkID=9240617 but the drawing file does NOT have a digital signature (option doesn't show up in Windows Explorer shortcut menu).
AutoCAD 2006 running on one of the machines will open the file without any problems. I verified in 2006 that the dwg does NOT have digital signatures with the SIGVALIDATE command. Also ran Audit & Purge commands in 2006 to check for any errors and rec'd none. Using Drawing Recovery in 2010 or 2011 does not work either.
I have searched the knowledge base and Autodesk forums extensively for a solution and have found nothing. I submitted a detailed report to Autodesk with this same information and am awaiting a response there also.
Thank you for your time.
New Member
VANAIRE
Message 2 of 6 (15,746 Views)
Re: AutoCAD 2011 (& 2010) FATAL ERROR: Unhandled Access Violation Reading ..
08-11-2010 09:19 AM in reply to: cdurb26003
You might try renaming your backup file to dwg and then try to open that. I would make a copy of your bak. file first.
Member
cdurb26003
Message 3 of 6 (15,730 Views)
08-11-2010 10:29 AM in reply to: VANAIRE
Thanks for the suggestion. I did as you suggested and I was able to open the drawing once.
It prompted me to cancel the open due to errors and run the Recovery (I elected not to do so since every attempt at recovery has failed so far).
I then ran an Audit & Purge to see if anything was wrong and of course it found nothing. I then saved the drawing file and closed it.
Tried opening it again and rec'd another FATAL ERROR. Tried to repeat the above process and it failed again.
It may just be that the file is corrupted beyond repair, but hopefully there's a solution out there.
Valued Mentor
stevenelliott3894
Message 4 of 6 (15,713 Views)
08-11-2010 11:39 AM in reply to: cdurb26003
Just a thought, but try saving it as a DXF file and then reading that file back into AutoCAD. This has worked for me on occasion.
Steven Elliott
When I was a little bitty boy, my grandmother bought me a cute little toy. Silver bells hangin' on a string... she told me it was my ding-a-ling-a-ling!
Member
cdurb26003
Message 5 of 6 (15,694 Views)
08-11-2010 02:06 PM in reply to: stevenelliott3894
Same result as renaming the .bak file. I was able to get in once and it still asked to Recover the drawing due to errors.
What I ended up doing was to open the drawing in 2006, copy everything in Model space from 0,0,0 and paste into a new drawing in 2011, then simply re-create the viewport(s).
I guess it was simply a corrupt drawing, since the new file opens with no trouble at all.
Thanks again for all the suggestions!
Valued Mentor
stevenelliott3894
Message 6 of 6 (15,668 Views)
08-12-2010 05:11 AM in reply to: cdurb26003
FYI
When you want to duplicate a layout in another drawing, right click on the layout tab in the destination drawing and create a new tab 'From a Template' and you can then select the source drawing and the exact layout tab you want to import.
Steven Elliott
Post to the Community
New Post
Announcements
Do you have 60 seconds to spare? The Autodesk Community Team is revamping our site ranking system and we want your feedback! Please click here to launch the 5 question survey. As always your input is greatly appreciated.
