AutoCAD 2010/2011/2012
Member
Marc.Gager
Message 1 of 9 (1,862 Views)
AutoCAD 2010 x64 Update SP2
1862 Views, 8 Replies
02-23-2011 09:30 AM
Soooooo....
My CAD crashes every so often and the error reporter suggested I install service pack 2.  I am running the 64 bit version of Cad and of Windows 7.  When I download the 64 bit version it tells me "Cannot Install As This is not a Win32 version"  Then I try the 32 bit version and it also won't work.
WTF am I doing wrong?  Help?
Valued Mentor
stevenelliott3894
Message 2 of 9 (1,636 Views)
Re: AutoCAD 2010 x64 Update SP2
02-25-2011 01:18 PM in reply to: Marc.Gager
Are you sure you didn't install the 32-bit version of AutoCAD in 64-bit Windows?
Steven Elliott
When I was a little bitty boy, my grandmother bought me a cute little toy. Silver bells hangin' on a string... she told me it was my ding-a-ling-a-ling!
Member
Marc.Gager
Message 3 of 9 (1,630 Views)
02-25-2011 01:27 PM in reply to: Marc.Gager
Nope.  I doubled chekced the disk and I used the 64 bit version.
Even if that was the case, I should then be able to use the 32 bit SP2 update which didnt work.
It still keeps on crashing.  Any thoughts.... anyone... help?
*Expert Elite*
pendean
Message 4 of 9 (1,628 Views)
02-25-2011 01:28 PM in reply to: Marc.Gager
x64 is in the name of the downloaded file from Autodesk, there is no mistaking what you downloaded: are you just downloading the same wrong file instead?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
Member
Marc.Gager
Message 5 of 9 (1,623 Views)
02-25-2011 03:04 PM in reply to: Marc.Gager
The file I am downloading is
autocad2010update2x64.exe
I am using AutoCAD MEP 2010.  I dont see an update section for MEP so maybe that is the problem?  If so, why would the error reporter send me to that file.
The message I get is:
THE SERVICE PACK COULD NOT BE INSTALLED BECUAS THE EXPECTED AUTODESK PRODUCT COULD NOT BE LOCATED ON YOUR COMPUTER
Member
jschmidt.allenshariff
Message 6 of 9 (1,394 Views)
04-12-2011 01:05 PM in reply to: Marc.Gager
I am having the same issue on multiple machines, was this ever resolved?
*Expert Elite*
pendean
Message 7 of 9 (1,392 Views)
04-12-2011 02:06 PM in reply to: Marc.Gager
The error message comes up when you are not using the exact version of AutoCAD the update is expecting: by chance is your R2010 seat part of a REVIT or INVENTOR package?
Or is this a vertical that is running "as AutoCAD"?
Member
Message 8 of 9 (1,380 Views)
04-13-2011 04:43 AM in reply to: pendean
Mine is part of a Revit Suite.
New Member
CARRIE
Message 9 of 9 (744 Views)
10-21-2013 10:11 AM in reply to: Marc.Gager
Did you ever resolve this issue? I am having the same problem with pack 1. It says it can't install without 'ACAD.MSI', but I put in the installation disk and "it could not be found". Any clue?
Thanks.
Post to the Community
New Post
Need installation help?
