I need AutoCAD 2010 for school but I can not find it on the site are not coping well, I'd like some help so that will give me a link...
Thanks in advance.
If you are a student, you can use http://www.autodesk.com/education/student-software/university/popular
If you google "autocad educational version" you may be able to get a permanent free version instead of the 36-mo trial above.
thanks for the reply, I found this, but when I choose the version that I want to take off is not offered to me in 2010, the closest that the 2011 ... if there's a significant difference?
There are some differences between AutoCAD 2010 and 2011. Check out this >Link< to see the main differences. Or do a www search for AutoCAD 2011 New features...
If your school uses 2010 and you downloaded 2011 to your home computer, remember to ALWAYS save a file on your home computer as a 2010 file - otherwise your school's computer will not be able to open it. This can be done when you use "save as" - in the "save as" window that appears, right under the place where you type the name of the file, there's a dropdown menu for which version of AutoCAD it should be saved as.
Hi Morgan, Save downs between 2011 and 2010 would not be neccessary. 2010-2012 share the same file format. If you take a look at how these forums are organized, Autodesk has grouped the version's years based on shared file format.
I again have a problem, when start AutoCAD asks me specify the license server system and then asks computer name of the license system ... I did not know what it should be, so I searched the site and found it ... But the problem is when you run the setup and I would go to what tools and ... not that I run setup, I'd be very grateful if someone could help with this problem because we urgently
and sorry for bad language
Hi MickeY,
I'm not quite sure how to help you with this. Try creating a new post in the >Installation and Licensing Forum< to get the best help on your new problem.
If you have a hard time getting things across in English try writing it out in your native language along with an English version. There are a lot of people here who also don't speak English 😉
