Hi guys
Can someone please tell me from where to download " AutoCAD 2010 ". In this website I have searched everywhere but can't found it. It offers to download AutoCAD 2011 - 2014 but I want to download 2010. If anyone knows, please help me.
Thanks.
Solved by Mark.Lancaster. Go to Solution.
Hi imtiaz.lalani,
Refer to the links below to download AutoCAD 2010.
- AutoCAD 2010 - 32 bit
- AutoCAD 2010 - 64 bit
How about the down load for the 2010 English version? I have a couple of lighting software programs that I need the 2010 version.
Welcome to the community Ron!
You can access most current + previous supported version download links (including AutoCAD Civil 3D 2010) through Matt, our Virtual Assistant.
From Matt: Download and Installation -> Software Download Links -> I need to redownload my product
Should you run into an activation error, typically resulting from an upgraded license and or reaching the activation limit on a given license, our License Assistance Team would be able to help facilitate an activation code.
Please accept as a solution if this fully answers your inquiry, or reply with additional questions as needed.
welcome @Anonymous.autodesk.com!
>> How can I reinstall it on my new hard drive?
@Anonymous
Welcome to the community.
If you don't have the original media than you most likely out of luck. 2010 is retired and no longer support by Autodesk, thus there's no live download for this version. In addition I assume since your hard drive failed that you installed a newer OS, is that correct? If so the 2010 version is not going to work on that either.
Mark Lancaster
& Autodesk Services MarketPlace Provider
>> the the serial no of autocad 2010
You have got it when you bought AutoCAD.
No one here in the forum can know your serial number.
- alfred -
Doesn't matter if you get one ..it can't be activated:
What about products that didn’t use the year as a version (for example, R10)?
All products using a non-year version scheme are included in the v2010 or earlier set of releases and can no longer be activated after August 31, 2019.
The person you tagged for help doesn't work for Autodesk anymore
This is an old thread and AutoCAD 10 isn't able to be activated anymore
https://knowledge.autodesk.com/contact-support/websupport/finding-download
But you likely won't be able to activate it @Oktarindi610
https://knowledge.autodesk.com/support/autocad/learn-explore/caas/simplecontent/content/previous-ver...
>> What is serial no. & product key of Autocad 2010 64 bit?
Sorry, how should anyone in the forum know what is your serial number? You have bought it, so you are the one who can know that.
The product key for AutoCAD 2010 is 001B1
- alfred -
