I have an old drawing and I am trying to turn the floor plan 180 deg. The plan turn. However the door symbols stays where they were. I tried to explode the drawing and then turn. Have the same result. I tried copy the floor plan and pasted on a new drawing. It copies the lines - not the door swing.
I do not what to do to turn the drawings 180 deg. I have attached the drawing. I need the plan marked new to be turned 180 deg.
Can somebody help?
Thanks.
Solved by Patchy. Go to Solution.
