I have a custom addin that runs an ARX file and an DLL file.
To auto load it I add some keys in registry.
For AutoCAd2010 the registry is:
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R18.0\ACAD-8001:409\Applications\eDocAcad]
"LOADCTRLS"=dword:00000002
"LOADER"="E:\\User\\EGROU\\V7.0\\eDocAddIns\\eDocAcad2010Addin.arx"
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R18.0\ACAD-8001:409\Applications\eGrouAcad]
"MANAGED"=dword:00000001
"LOADER"="E:\\User\\EGROU\\V7.0\\eDocAddIns\\eGrou.ACAD2010Addin.dll"
For AutoCAd2011 the registry is:
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R18.1\ACAD-9001:409\Applications\eDocAcad]
"LOADER"="E:\\User\\EGROU\\V7.0\\eDocAcad2010Addin.arx"
[HKEY_LOCAL_MACHINE\SOFTWARE\Autodesk\AutoCAD\R18.1\ACAD-9001:409\Applications\eGrouAcad]
"LOADER"="E:\\User\\EGROU\\V7.0\\eGrou.ACAD2010Addin.dll"
In AutoCAD2010 load right when AutoCAD starts and works well, but in AutoCAD2011 don't load and don't give any error.
When I load manually with commands APPLOAD and NETLOAD loads right and works well.
What I am doing wrong to not load when AutoCAD2011 starts?
Thanks & Regards,
Rui
Solved by artc2. Go to Solution.
Are the paths to the files really supposed to be different for the 2011 registry entries (the eDocAddIns directory is missing in the 2011 paths)?
