AutoCAD Forum
Auto Dim Style
7 REPLIES 7
Message 1 of 8
Rikkes
361 Views, 7 Replies
Auto Dim Style
I made a button with th following command; ^C^C_-LAYER;_Make;Bematen;;_dimlinear. When I click that button, I change automaticaly to layer 'bematen'. (measure)  This works fine.
Is it possible to change the dim style with the same click to a predefined style?
7 REPLIES 7
Message 2 of 8
pendean
in reply to: Rikkes
Explore -DIMSTYLE command (there is a dash in the name).
Message 3 of 8
Rikkes
in reply to: pendean
Tried that but didn't find the right formula... That's why I posted this item.
Message 4 of 8
jggerth1
in reply to: Rikkes
-dimstyle;restore;<name of your dimstyle>
Message 5 of 8
Rikkes
in reply to: jggerth1
I have to enter aI tried this:
^C^C_-LAYER;_Make;Bematen;;-dimstyle;restore;Layout2;;_dimlinear
When I use this it prompts me with 'Enter a dimension style option' with the Restore option highlighted. When I click Restore, I have to choose a Dim Style. When I Escape the dimstyle goes to Layout2.
Strange...
I think there's still someting missing in the formula.
Message 6 of 8
pendean
in reply to: Rikkes
You have too many <enter> if I type it out at the command line as a test: did you test it that way first?
Message 7 of 8
Rikkes
Sorry Dean, I don't understand what you mean. When I type dimstyle at the command line I get the dimstyme popup menu.
There must be a way to do what I want...
Message 8 of 8
Rikkes
in reply to: Rikkes
Haaaa! Found it!
Very simple BTW...
I first recorded a macro while changing layer and dimstyle. Then saved it under 'layout2' and added the dimlinear command like this.
^C^C_layout2;_dimlinear
Works fine!
Maybe this is useful for other people.
Bye!
”Boost
