I made a button with th following command; ^C^C_-LAYER;_Make;Bematen;;_dimlinear. When I click that button, I change automaticaly to layer 'bematen'. (measure) This works fine.
Is it possible to change the dim style with the same click to a predefined style?
Solved by Rikkes. Go to Solution.
I have to enter aI tried this:
^C^C_-LAYER;_Make;Bematen;;-dimstyle;restore;Layout2;;_dimlinear
When I use this it prompts me with 'Enter a dimension style option' with the Restore option highlighted. When I click Restore, I have to choose a Dim Style. When I Escape the dimstyle goes to Layout2.
Strange...
I think there's still someting missing in the formula.
Sorry Dean, I don't understand what you mean. When I type dimstyle at the command line I get the dimstyme popup menu.
There must be a way to do what I want...
Haaaa! Found it!
Very simple BTW...
I first recorded a macro while changing layer and dimstyle. Then saved it under 'layout2' and added the dimlinear command like this.
^C^C_layout2;_dimlinear
Works fine!
Maybe this is useful for other people.
Bye!
