AutoCAD 2010/2011/2012
lassi_tarri
Message 1 of 13 (536 Views)
$AUDIT_BAD_LAYER
536 Views, 12 Replies
04-27-2009 01:40 AM
Audit creates these layers: $AUDIT_BAD_LAYER. What are these for and how I can i delete them?
*Dean Saadallah
Message 2 of 13 (536 Views)
Re: $AUDIT_BAD_LAYER
04-27-2009 04:27 AM in reply to: lassi_tarri
LAYDEL command?
Dean Saadallah
http://LTisACAD.blogspot.com
Valued Contributor
MichelLoftus
Message 3 of 13 (536 Views)
04-27-2009 05:42 AM in reply to: lassi_tarri
In many cases these layers are empty and a simple purge will do the trick.
Valued Contributor
DianneS
Message 4 of 13 (536 Views)
04-27-2009 11:54 AM in reply to: lassi_tarri
Usually when I delete or purge these layers, then do an audit with fixes, the layers are added back. So I just leave them. Does anyone know why deleting them causes an error, or what error causes them in the first place?
Dianne
*Rick Moore
Message 5 of 13 (536 Views)
04-27-2009 11:57 AM in reply to: lassi_tarri
When this has happened here I use AECTOACAD which creates another cleaned
file that does not have the layers.
Rick Moore, AIA
www.bgkarchitects.com
*Glenn Pope
Message 6 of 13 (536 Views)
04-27-2009 01:59 PM in reply to: lassi_tarri
One thing that I have found that causes this is having the Defpoints
layer turned off and/or frozen. This also includes any viewport
overrides in any layouts.
Active Contributor
dawnhapt
Message 7 of 13 (536 Views)
05-01-2009 08:02 AM in reply to: lassi_tarri
Don't repeat the Audit command until you re-open your drawing and this shouldn't happen.
AUDIT
PURGE
SAVE
CLOSE
OPEN
AUDIT - You should see no errors this time and no recreated layers.
Valued Contributor
DianneS
Message 8 of 13 (536 Views)
05-05-2009 11:52 AM in reply to: lassi_tarri
Tried this and it works. Thanks for the tip.
Dianne
*Pro
Modman_4
Message 9 of 13 (536 Views)
06-16-2009 01:01 PM in reply to: lassi_tarri
What about writing a new block consisting of the entire drawing?
I hope my info was useful, but if by some odd chance it actually solved your issue, feel free to mark your post as "Accept as Solution". Thanks! :smileyhappy:
Active Contributor
dana_kennell
Message 10 of 13 (536 Views)
09-30-2009 08:09 AM in reply to: lassi_tarri
What if none of this works. I'm having this problem with a drawing that is a template for all projects. If I delete the layer, it just comes back. It won't allow me to purge it. Defpoints is not off anywhere. Is there a way to identify what is causing the problem? I'm actually using C3D, which makes it hard to just make a block out of the drawing. Right now there is nothing in the file but an xref for the titleblock, which I've already tried to recover, and a block of attributes to go with it. If anyone can provide further insight, I'd appreciate it. I really don't want this layer in all future files of this type. Thanks.
Announcements
Need installation help?
