AutoCAD Forum
Attributed Text Style Change?
2 REPLIES 2
anderson51
322 Views, 2 Replies
Is there a way to change the text styles, lets say from "Standard" to "Romans", all at once within an attributed block, or do you have to update each tag attribute individually?
2 REPLIES 2
you can edit the blockdefinition, change there the attributedefinitions to have the other textstyle. After finishing the blockeditor with saving start command _ATTSYNC and all block-insertions of that type will get updated.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
Beautiful!
Thank you sir!
”Boost
