good day,
i'm having difficuly attaching a pdf into cad dwg. every time i enter pdfattach command this what appears "Path to PDF file to attach"..
normally a window will appear when i insert a pdf but now no window appears but this one "Path to PDF file to attach"
i know that there is a set-up in cad so this won't appear again but i forgot..
please help me....
thanks
Solved by Alfred.NESWADBA. Go to Solution.
can you upload a screenshot of the message you get?
And another option: start command _XREF ... and within this palette-window right click into the area of the files and use "Attach PDF" in the context menu ... same issue?
- alfred -
well, is it the sysvar FILEDIA you are looking for (set to 0 and should be 1)?
If not ... there was no screenshot attached.
- alfred -
to Sir Alfred NESWADBA,
thanks a lot....
you saved my day...
i will never forget this command FILEDIA.. hahaha
God bless you...
