AutoCAD 2010/2011/2012
New Member
elmasry.ayman
Message 1 of 2 (396 Views)
Arithmetic operation in a position field
396 Views, 1 Replies
02-11-2012 12:31 AM
Hi, I'm using a position field as an attribute for a block. This is what I use:
%<\AcObjProp.16.2 Object(%<\_ObjId 2118086344>%).InsertionPoint \f "%lu2%pt2%pr4%ps[+, M]%ct8[0.001]">%
What I would like to do is an arithmetic operation of addition, something similar to how 'CAL works. In this particular case I would like to add the value of 100,000 before the conversion factor, or 100 after the conversion factor.
Thanks.
vladimir.michl
Message 2 of 2 (371 Views)
Re: Arithmetic operation in a position field
02-12-2012 01:36 PM in reply to: elmasry.ayman
Yes, you can add values to automatic properties. See the tip:
http://www.cadforum.cz/cadforum_en/qaID.asp?tip=6381
The resulting expression will look similar to:
%<\AcExpr (100+%<\_FldPtr 305306904>%) \f "%ps[+, M]">%
and
%<\AcObjProp Object(%<\_ObjId 2129671616>%).InsertionPoint \f "%lu2%pt2">%
Vladimir Michl, www.cadstudio.cz  www.cadforum.cz
