AutoCAD 2010/2011/2012
imadhabash
Message 1 of 8 (709 Views)
AREA precision units
709 Views, 7 Replies
06-13-2012 02:33 AM
Hi every body,
i have a werid number appear when a get the AREA of the attached rectangles shapes especially when i use SMD ucs.
for instance see the rectangle C07  74X39=2886.00000000 BUT i get the area like 2886.000000003.
why the precisions dosesn't all 0 !!!!!!!
kindly see the attachment
thanks
Please mark this as the solution if it resolves your issue.Kudos gladly accepted. ⇘
JDMather
Message 2 of 8 (706 Views)
Re: AREA precision units
06-13-2012 03:40 AM in reply to: imadhabash
For all practical purposes those two numbers are equivalent.
Search for information on floating point math calculations.
What are your units?
What will be your measuring device?
What is your manufacturing/construction process?
Autodesk Inventor 2014 Certified Professional
Inventor Professional 2015-SP1 64-bit
Active Contributor
dlipscombe
Message 3 of 8 (694 Views)
06-13-2012 07:34 AM in reply to: imadhabash
The accuracy is 0 before you rotate the rectangle, if you rotate in increments less than 90 it looses this accuracy giving an inaccuracy such as yours +/- of the value. But as noted the accuracy is pretty good for all practical purposes.
JDMather
Message 4 of 8 (674 Views)
06-13-2012 03:43 PM in reply to: dlipscombe
Pretty good?  It is dead on for all practical purposes.
I think units (mm, M, light years...) need to be specified along with magnitude to have any real meaning.
Active Contributor
dlipscombe
Message 5 of 8 (667 Views)
06-14-2012 12:45 AM in reply to: imadhabash
Autocad is a precision software, you dont expect to get two different values just because you rotated an object 30°, no matter how minute the discrepency it should give the same reading in all circumstances, after all rotating an object doesnt change the object? Yes your right it is dead on for all uses, nobody ever needs that sort of accuracy.
JDMather
Message 6 of 8 (657 Views)
06-14-2012 06:00 AM in reply to: dlipscombe
What is the precision of AutoCAD software. Be specific.
What is the programing routine for calculating the new position. Be specific. (you may simplify this one with hand-calc trig rather than specific programing algorithm)
Active Contributor
dlipscombe
Message 7 of 8 (654 Views)
06-14-2012 06:22 AM in reply to: imadhabash
As we can see from the OP they offer 8 decimal places but can only deliver 7, should not offer something you cannot achieve.
dbroad
Message 8 of 8 (650 Views)
06-14-2012 07:00 AM in reply to: dlipscombe
Precision is not about decimal places but significant figures.  There are 13 significant figures, not 8 decimal places.  The original drawing did not have perfectly drawn rectangles.  The dimensions were off in the 12th significant figure (which is superb unless you want perfection).
There is no need to dimension or worry about these kinds of extreme precisions that cannot be measured or produced by machine.  A typical surveyor might measure with an error of 1 part in 5000. So a 74m property might actually be 74.01m or it might be 73.99m.  The area listed is well within the measurable precision.
