AutoCAD 2010/2011/2012
Member
juuki
Message 1 of 6 (2,313 Views)
APPCRASH KERNELBASE.dll
2313 Views, 5 Replies
12-26-2012 11:43 AM
hello, i recently install on my laptop windows 7 ultimate SP1 and autocad 2012 and came on one problem. when i go to hatch-pick point and select point from any region form A1 to A5(in attachment is drawing) it shows me this error:
Problem signature:
Problem Event Name: APPCRASH
Application Name: acad.exe
Application Version: 24.2.51.0
Application Timestamp: 4d4b77cd
Fault Module Name: KERNELBASE.dll
Fault Module Version: 6.1.7601.17965
Fault Module Timestamp: 506dbd3f
Exception Code: c0000005
Exception Offset: 00006c6b
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1050
Additional Information 1: 59d2
Additional Information 2: 59d28f4851ee3e61e3aa57edc696ac9e
Additional Information 3: d43b
Additional Information 4: d43b85353e13bc67c0876e48eb2865c9
Read our privacy statement online:
http://go.microsoft.com/fwlink/?linkid=104288&clcid=0x0409
If the online privacy statement is not available, please read our privacy statement offline:
C:\Windows\system32\en-US\erofflps.txt
when i do same think on other laptop (autocad 2012) still same problem. i also try to done it on www.autocadws.com online and it shows me error "a closed boundary cannot be determined".
in attachment is autocadcad drawing
I can confirm that issue, I tried it with AutoCAD 2012SP2 and 2013SP1.1 and crashed with both versions.
At the moment I have no real solution, but a workaround (and an idea what's going on behind AutoCAD).
The workaround:
move a spline including it's text-informations to a position where the SPLINE does not have neighbours, then hatch it and move the objects (including the new hatch) back to the original location. Do that for each SPLINE separately.
The idea what's the source of the problem:
SPLINES are never straight and equal, so your splines e.g. between A3 and A5 is not recognized as "one" border, the SPLINE from A5 is sometimes crossing inside of A3 sometimes outside, and that maybe on hundreds of positions. So the creation of the hatch sees not just 3 text-objects as island, but hundreds additional of crossing borders ... and that creates something like a stack overflow.
You can verify that by zooming very close to the borders between different regions.
- alfred -
Alfred.NESWADBA
Message 2 of 6 (2,307 Views)
Re: APPCRASH KERNELBASE.dll
12-26-2012 12:13 PM in reply to: juuki
The workaround:
- alfred -
Alfred NESWADBA
Member
juuki
Message 3 of 6 (2,302 Views)
12-26-2012 12:31 PM in reply to: Alfred.NESWADBA
thanks for fast replay the workraound solution work for me and explanation is very fine and logical.
but i have one more problem. when i go to draw-line and just came with mouse in this area (in attachment) same error shows
also with any other command as copy, move . . . when object snap is turned on
Alfred.NESWADBA
Message 4 of 6 (2,296 Views)
12-26-2012 12:43 PM in reply to: juuki
my bet: you have started the LINE command having objectsnap active and within the objectsnaps you have "INTERSECTION" active (at least that is the reason that I crash, turning it off make my AutoCAD not crashing).
HTH, - alfred -
Alfred NESWADBA
Member
juuki
Message 5 of 6 (2,293 Views)
12-26-2012 12:54 PM in reply to: Alfred.NESWADBA
true, alfred you are good :smileyhappy: thank you
why autocad crash when intersection is active?
Alfred.NESWADBA
Message 6 of 6 (2,291 Views)
12-26-2012 01:00 PM in reply to: juuki
Because the "parallel/dist-0 SPLINES" create hundreds (or thousands) of INT-points :smileywink:
- alfred -
Alfred NESWADBA
