AutoCAD 2010/2011/2012
Distinguished Contributor
dbd63
Message 1 of 7 (414 Views)
Aperture jumpy only over objects
414 Views, 6 Replies
02-23-2012 11:53 AM
My aperture / crosshairs seems to have a magnetic attraction to all objects in drawings.  Over an empty area, motion is smooth.  When crossing over any object(s), be they in Model Space or a Layout, the cursor is attracted to objects.  Is this an AutoCAD setting that I'm not aware of, or is this a graphics card / hardware acceleration issue?
Uncheck "Show rollover ToolTips" under "Tools/Options/Display" or Set "ROLLOVERTIPS=0",
that should work.
pendean
Message 2 of 7 (386 Views)
Re: Aperture jumpy only over objects
02-24-2012 05:46 AM in reply to: dbd63
So what do you have turned on, SELECTIONPREVIEW and/or Quick Properties and/or Selection Cycling and/or any palettes (even minimized)?
Dean Saadallah Blog | Facebook | Google+ | Twitter | PINS
dbd63
Message 3 of 7 (383 Views)
02-24-2012 06:05 AM in reply to: pendean
SELECTIONPREVIEW = 0
QPMODE = -1  (what does -1 do?  That value is not described in the Help)
HIGHLIGHT = 1  (Setting highlight to 0 has no effect on the jumpy effect)
Selection Cycling: is there a setvar that controls that?  I thought selection cycling was activated only by a keystroke combination.
Palettes: Xref palette, Tool palettes, Properties palette
pendean
Message 4 of 7 (379 Views)
02-24-2012 06:51 AM in reply to: dbd63
I don't recall if R2010 had SELECTIONCYCLING variable of not.
So R2010 is not new, what changed recently?
it's not the other things I noted, good: are you using Windows7?
Is AutoCAD's hardare acceleration toggled on/off?
dbd63
Message 5 of 7 (373 Views)
02-24-2012 08:40 AM in reply to: pendean
Windows 7- yes.
What's new recently- last week my profile went in the dumper- don't recall what caused it, but I had to rebuild the interface and save as a new profile.  I've been chasing various menus and config files around since.  I can't say for sure that the jumpy cursor thing was not active before rebuilding my profile, but I think I would have noticed.
Hardware Acceleration: enabled.  A screen cap of the Manual Tuning dialog box is attached.
Member
Rhyzade
Message 6 of 7 (371 Views)
02-24-2012 08:46 AM in reply to: dbd63
that should work.
dbd63
Message 7 of 7 (353 Views)
02-24-2012 09:46 AM in reply to: Rhyzade
First post, Rhyzade?  You're batting 1000!  Thanks- what a relief!
Dan
