Hi Folks,
I've created a nifty annotative block that will scale and orient itself to my layout. This is important as I have many different orientations to generate. The issue comes when I include a leader so that the plan reader will understand what is being labeled. My question: how can I incorporate a leader such that it remains connected to the block (that is going to rotate) and the point of interest (that will not be moving)? Examples of the issue are below. Thanks!
This looks great:
This looks awful:
Unsure if it's dynamic. You may know better. I am sure it's annotative as I had to select that property in order to make use of the "match orientation" feature.
Block is attached. I haven't incorporated the leader into the block at all yet. Would love ideas! Thanks,
I'm using Civil 3D 2011. When I enable annotative properties for this block, I'm also able to select match orientation. So, this block rotates itself so that it is always 0 degrees rotation no matter the viewport rotation.
I just tried working with a multileader. It's a great suggestion as I haven't tried before. It will not allow me to select this block, but I can select others to use. I wonder if that is because it's an annotative block?
