AutoCAD Forum
all objects showing as 1 layer
2 REPLIES 2
283 Views, 2 Replies
I have a drawing with objects on multiple layers, however when I select an object, they all show as whtever layer is showing.  If I open the drawing on antoher machine, everything works properly with multiple layers.
2 REPLIES 2
pendean
Sounds like your PICKFIRST variable is turned off (or your AutoCAD Properties palette is messed up and you must reinstall the program).
Start with the easier fix.
in reply to: pendean
Perfect! I just reset the pickfirst variable to (1) and everything works great. Thank you!
”Boost
