i don't know why all object on Model tab don't show correct color, though i set color follow by layer. otherwise object on layout tab show correct color by layer.
Solved by hwalker. Go to Solution.
Welcome to the Forums
I've just had a look at your drawing and found the problem.
Modelspace is using the monochrome.ctb file which is why everything is white/black.
Go into modelspace and call up the properties tab either by
CTRL+1 or
typing in PROPERTIES at the command line
When the properties box comes up, look for the line which says PLOT STYLE TABLE. You will see it says MONOCHROME.CTB change that to NONE or one which you use.
Now at the command line type in REGEN. Your lines should now be in colour
Howard Walker
