i don't know why all object on Model tab don't show correct color, though i set color follow by layer. otherwise object on layout tab show correct color by layer.
Solved by Alfred.NESWADBA. Go to Solution.
change to ModelSpace (tab "Model"), run command _PAGESETUP, select "Model" and button "Modify" ==> you see that the plotstyle is set to "monochrome" and the checkbox "Display plot styles" is activated ==> uncheck it and you have your colors back 😉
HTH, - alfred -
Thank for your helping. I do follow by your introduction now my drawing had color back. thank you so much
