Currently we are still using Release 2012, but, will be switching to 2015 as soon as it CDs arrive.
I still have Menu Bars, located above the Ribbons.
When I don't know where a Command is on a Ribbon, I use the Menu Bar.
Well, I don't know how much longer Menu Bars will be available, so, I'm using the Ribbons as much as I can.
There are times with tight Dimensions when we move the Text for clarity.
Later, the Dimension may become longer, so on the Menu Bar, I go to "Dimension", "Align Text", "Home".
I cannot find that on the Ribbon.
I go to "Annotate", then "Dimensions", then I cannot find the Align Text / Home.
Any help out there? -KLYPH
Solved by KLYPHY. Go to Solution.
Solved by braudpat. Go to Solution.
To display command line press Ctrl+9 and enter command D(for changing dimension style)
OR enter command: dimedit to align text in dimension or select option Home.
Is it want you want?
Thanks for your reply, but, no, that's not what I was looking for.
I do ususally use the Command Line because, as you know, it's faster, but it is also good to know which button to push.
As I was saying, I know how to send dimension text back to its home using the older Menu Bar.
Well, Menu Bars have been replaced with Ribbons.
When we go to Release 2015, the Menu Bars will probably not be available any more.
So, what I am looking for is the same thing, but using a Ribbon.
Any ideas out there?
Hello from France
Not sure to well understand your Topic/Question !?
But on my french ACAD 2012-2014 (Ribbon Interface - Annotate) I use this icon (see the image) to send back text dim to original position (Center) ...
Sorry I haven't ACAD 2015 on my current PC !
Patrice BRAUD
Yes , exactly!Got it!Now I understood what do you want to ask.
Thank you Pat for giving solution.
