AutoCAD Forum
Align or rotate objects parallel to X axis
5 REPLIES 5
demus72
8031 Views, 5 Replies
Is anyone aware of a lisp routine or macro that will either rotate or align selected objects so they are parallel to an axis on the current UCS? Specifically, when placing mtext to label an object. I typically align my ucs to the object then create the text so it is parallel to the object. It would be great if I could create the text with a rotation of 0, align my ucs to the object to be labeled and then with a single click, select the text making it parallel to the X axis. Would anyone care to share their lisp or macro?
Thanks for the help.
5 REPLIES 5
FSJ_Mo
in reply to: demus72
You should just type out your text at any rotation (it doesn't matter) and use the "TORIENT" command. It allows you to align your text to any 2 points that you pick, and you don't have to muck about with your UCS.
Alfred.NESWADBA
you might use parametrics? E.g. start command _GCHORIZONTAL and select your textobject (you might remove the constraint if you don't need it later on).
For other parts look to the "Parametric" ribbon.
- alfred -
Alfred NESWADBA
(not an Autodesk consultant)
demus72
in reply to: FSJ_Mo
Thanks for the reply FSJ_Mo. I have never used Torient before. I will look into that command.
As we all know, there are many ways to accomplish the same task in Autocad and everyone has their own personal preferences on how to go about accomplishing that task. More than likely, most prefer what ever method they learned first. I work with the UCS a lot. I use a button on a toolbar to align my UCS to an object which takes two clicks. From there, if I could click on another toolbar button with a macro built to give the selected text a rotation of 0, select the text, that would only take two clicks. If such macro exists and I could track it down, I could accomplish my task in four clicks. I'm simply trying to be more efficient.
Thanks.
Alfred.NESWADBA
You find my command also as a button in the parametrics-ribbon, so two clicks for alignment of an object to horizontal (or vertical or parallel to any object or ...)
You always have the chance to create your own buttons, it's up to you (and possible with AutoCAD 😉 ).
- alfred -
Alfred NESWADBA
nestly2
I think FSJ_MO's suggestion of TORIENT is going to be hard to beat using only what's built into AutoCAD..  You have the option of aligning the text with an object using only two clicks, using polar tracking, or specifying an absolute angle  (0 if you've already reoriented the UCS)  If the UCS is already aligned. This macro will align a text with the X-axis just by clicking the text  ^C^C_TORIENT;\;0;
Other possible solutions:
http://www.lee-mac.com/dtcurve.html
http://www.lee-mac.com/curvealignedtext.html
”Boost
